Weather-forecast in picture-elements
Have some challenges trying to get the weather icon (not state.icon) to show in picture-elements.
Dont face the same issue using other custom:cards.
Is this a limitation of the the weather-forecast card?
Any suggestions welcome?
The below shows the weather-forecast card correctly on its own in the dashboard.
type: weather-forecast
entity: weather.home_hourly
show_current: true
show_forecast: false
forecast_type: hourly
secondary_info_attribute: temperature
But when trying to do this within picture-elements i just get a print of below code:
type: picture-elements
elements:
  - type: custom:weather-forecast
    show_current: true
    show_forecast: true
    style:
      top: 40%
      left: 40%
image: /local/community/blank.png
You posted a different code for the weather card in these cases.
Do you have a suggestion on how to get weather-forecast icons shown in picture elements?
I am not getting the question.
Icons are part of the card.
Picture-elements card may contain CUSTOM cards.
Conventional cards should be wrapped inside custom:hui-element:
elements:
  - type: custom:hui-element
    card_type: weather-forecast
    entity: weather.home_openweathermap
    forecast_type: daily
    style:
      top: 20%
      left: 50%
  - type: custom:weather-card
    style:
      top: 65%
      left: 50%
image: /local/images/test/orange.jpg
elements:
    style:
      top: 65%
      left: 50%
Thank you for confirming this work. I must have an issue with the weather-card then, because when I use this code, i get the below screenshot.Screenshot 2023-10-01 142621
Do you have it installed?
Yes. works standalone as a card but not in picture-elements.
Check my post - a custom card is used inside picture elements.
Are you sure that custom:weather-card works as standalone ?
100%.
Source:
show_current: true
Screenshot 2023-10-03 164657
These are diff cards. You posted a screen with a standard card.
Check again my code.
If I use your code I get these results. Not like yours!
Weather Forecast card is available as a new card when adding to the dashboard, but not the weather-card
Custom cards (weather-card, hui-elements) should be INSTALLED.
They are not present in HA setup by default.
Find them in Github & install.
For beginners, the easiest way to install custom cards is via HACS. Google HACS and install it, then install these cards via HACS.
Thank you for your patience and help.
Solved now by installing Hui Elements completely missed installing this. Such a dumb ass thing to do.
While trying to help another member in the forums, i came accross the hui-element. I would like to use it to add a vignette on a map card. Whatever i do, the map does not display. Could i please ask for some help? Here is what i tried so far:
Code:
image: /local/vignete.png
elements:
    card_type: map
    entities:
      - entity: device_tracker.michael
    style:
      top: 50%
      left: 50%
If i put a different card it works:
Code:
elements:
    entity: weather.forecast_home
    style:
      top: 50%
      left: 50%
Is the map card supported by the hui-element?
Thank you
I have a similar question: I want to change the background on my picture-elements card/dashboard, so that when it rains, it shows a rain .gif file I made, and same with sunny, cloudy etc…
I have searched online repeatedly, and I find different half-answers, none of which seem to work. I can’t believe this is so difficult, but surely someone must have figured this out by now. Any help appreciated!
Can u url linc the correct one? Cant find one that have that namn only in hacs or when google.
