I didn’t do the update 2023.9 yet…
Just to be sure : now I have 3 open weather map integrations :
Am I correct that with the new update I only need one integration ? And does it matter how this one is configured ?
Thanks !
Thanks !
The information provided by the integrations is not changing. So if you use both daily and hourly forecasts for your automations or dashboard, you will still need one of each.
According to the integration docs, the onecall methods will result in only one API call every 5 minutes per instance, keeping you below the 1000 call daily limit for free accounts if you have both an hourly and daily instance.
