Weather forecast
Trying to build my first Home assistant page. I had the weather thing working but now it’s not. It’s saying
“ Entity must be specified
type: weather-forecast entity: ‘’
Here is the code. I think it’s missing some things
entity: weather.home
show_forecast: true
Any idea’s on what I screwed up? Thanks
What do you have in configuration.yaml for weather?
Do you have a weather integration?
When posting code try to use ‘</>’ button to format code.
Under dev tools (the hammer icon) type in ‘weather’ and see if you have any weather.
I’ll look when I get home tonight. I’m going to play in San Francisco today. But thanks.
Hello, Sorry it took so long to get back.
I went to Dev tools then clicked template. I did a shearch for weather it came back with
'The temperature is 25 °C.
'The sun rose 14 hours ago.
'For loop example getting entity values in the weather domain'
.The full code is
{## Imitate available variables: ##}
{% set my_test_json = {
  "temperature": 25,
  "unit": "°C"
The temperature is {{ my_test_json.temperature }} {{ my_test_json.unit }}.
{% if is_state("sun.sun", "above_horizon") -%}
  The sun rose {{ relative_time(states.sun.sun.last_changed) }} ago.
{%- else -%}
  The sun will rise at {{ as_timestamp(strptime(state_attr("sun.sun", "next_rising"), "")) | timestamp_local }}.
{%- endif %}
For loop example getting entity values in the weather domain:
{% for state in states.weather -%}
  {%- if loop.first %}The {% elif loop.last %} and the {% else %}, the {% endif -%}
  {{ state.name | lower }} is {{state.state_with_unit}}
{%- endfor %}.
Weather integration: Nope it is a bare bones system
Add a weather integration and that will give you the sensors to fill out your weather card.
Okay now to google how to do that. Thank you.
Easiest way is to go to:
Configuration
Integrations
Add Integration
type weather in the search bar and click the most appropriate selection.
I got it working. Thank you for all your help.
