I’ve been trying to create a sensor to sum the rainfall for the next 24 hours. For this I’m trying to use the Met.no integration to loop through the “forecast” attribute and sum the rainfall hour by hour, but I’m not having any success. Every code I try gives me an error when implementing the “forecast” attribute that contains the list of the different hours of the forecast. I’ll appreciate any help you can give me. I’ve already looked at a lot of examples and I can’t figure it out.
Here is my code:
- trigger:
- platform: time_pattern
# hours: /1
minutes: /1
- platform: homeassistant
event: start
- service: weather.get_forecasts
type: hourly
entity_id: weather.forecast_casa
response_variable: Pronostico
- name: Lluvia proximas 24 horas
unique_id: clima_lluvia_proximas_24_horas
unit_of_measurement: mm
icon: mdi:weather-rainy
state: >
{% set ns = namespace() %}
{% set ns.TotalPrecipitacion = 0 %}
{% for PronosticoPorHora in Pronostico.forecast %}
{% set ns.TotalPrecipitacion = 50 %}
{% endfor %}
{{ ns.TotalPrecipitacion | float(0) | round(2) }}
For this example, if the for loop could read the “forecast” attribute it should return 50 in the variable ns.TotalPrecipitacion, but it always returns 0 since it doesn’t enter the for loop. The error I get is:
Template variable warning: 'dict object' has no attribute 'forecast' when rendering '{% set ns = namespace() %} {% set ns.TotalPrecipitacion = 0 %} {% for PronosticoPorHora in Pronostico.forecast %} {% set ns.TotalPrecipitacion = 50 %} {% endfor %} {{ ns.TotalPrecipitacion | float(0) | round(2) }}'
In another example I made, when I implement the direct reading of the “forecast” attribute I get the error:
Error rendering state template for sensor.lluvia_proximas_24_horas: UndefinedError: 'dict object' has no attribute 'forecast'
Thank you very much for any comments you can give me.
