'weather.get_forecast' is deprecated
Hello all,
since HA version 2023.12.X I get these Warnings in my log:
2023-12-19 10:30:13.908 WARNING (MainThread) [homeassistant.components.weather] Detected use of service 'weather.get_forecast'. This is deprecated and will stop working in Home Assistant 2024.6. Use 'weather.get_forecasts' instead which supports multiple entities
2023-12-19 10:30:13.928 WARNING (MainThread) [homeassistant.components.weather] Detected use of service 'weather.get_forecast'. This is deprecated and will stop working in Home Assistant 2024.6. Use 'weather.get_forecasts' instead which supports multiple entities
These warnings are pretty self explained. Therefore I changed my template from this:
template:
  - trigger:
      - platform: state
        entity_id: weather.openweathermap_hourly
      - service: weather.get_forecast
          type: hourly
        response_variable: hourly
      - name: Weather Forecast Hourly
        unique_id: weather_forecast_hourly
        state: "{{ now().isoformat() }}"
        attributes:
          forecast: "{{ hourly.forecast }}"
  - trigger:
      - platform: state
          type: daily
        response_variable: daily
      - name: Weather Forecast Daily
        unique_id: weather_forecast_daily
        attributes:
          forecast: "{{ daily.forecast }}"
to this
template:
  - trigger:
      - platform: state
      - service: weather.get_forecasts
          type: hourly
        attributes:
          forecast: "{{ hourly['weather.openweathermap_hourly'].forecast }}"
  - trigger:
      - platform: state
          type: daily
        attributes:
          forecast: "{{ daily['weather.openweathermap'].forecast }}"
Sadly these warnings are still shown and doesn’t disappear.
I also searched for any automation or template which is using this deprecated service ‘weather.get_forecast’, but I can’t find it.
Is it possible that this warning is buggy or is there any problem on my site?
Did you try restarting Home Assistant instead of reloading templates?
Yes, I also restarted the complete HA OS.
Try searching your entire config directory (VSCode is good for this).
Just did a search through the files.
As you can see, the only matching results are already updated to “weather.get_forecasts”
Could be.
If it’s designed to simply search for the string weather.get_forecast then it will find a match in weather.get_forecasts.
Please report this as a new issue here:
Done: ‘weather.get_forecast’ is deprecated - false warning inside the ha log · Issue #106097 · home-assistant/core · GitHub
@tom_l Thank you for your time. I found the issue on my system.
It seems like, that the “Studio Code addon” didn’t saved my file changes.
