Weather.home_assistant
Hassio 100.3 Docker. Host Ubuntu in virtual box. I’m taking host system snapshots for quick recovery. Now, after restarting the system, the Weather.home assistant disappears.
In logs
Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 406, in _async_add_entity
    await entity.async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/met/weather.py", line 82, in async_added_to_hass
    await self._fetch_data()
  File "/usr/src/homeassistant/homeassistant/components/met/weather.py", line 146, in _fetch_data
    self._update()
  File "/usr/src/homeassistant/homeassistant/components/met/weather.py", line 153, in _update
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 286, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 314, in _async_write_ha_state
    attr.update(self.state_attributes or {})
  File "/usr/src/homeassistant/homeassistant/components/weather/__init__.py", line 168, in state_attributes
    forecast_entry[ATTR_FORECAST_TEMP],
KeyError: 'temperature'
In the list of sensors Weather.home assistant disappeared. The weather card does not work.
