Weather icon with ESPHome yaml
I am trying to display the weather icon from Accuweather/OpenWeather/PirateWeather whichever is the simplest on a 7.5 e-paper display. I want to simulate something similar to what madelena is doing. However this requires modifying the configurations.yaml, which I would like to prevent, to improve the simplicity of integrations. Is this possible, if yes, can someone please help me to achieve this using the following yaml code?
esphome:
  friendly_name: Ink Display 1
  on_boot:
      priority: 200.0
      then:
        - component.update: eink_display
        - delay: 10s
        - logger.log: "Initial sensor data received: Refreshing display..."
        - lambda: 'id(initial_data_received) = true;'
        - script.execute: update_screen
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "abc"
ota:
# Global variables for detecting if the display needs to be refreshed. (Thanks @paviro!)
globals:
  - id: data_updated
    type: bool
    restore_value: no
    initial_value: 'false'
  - id: initial_data_received
    type: bool
    restore_value: no
  - id: recorded_display_refresh
    type: int
    restore_value: yes
    initial_value: '0'
# Script for updating screen - Refresh display and publish refresh count and time. (Thanks @paviro!)
script:
  - id: update_screen
    then:
# Check whether the display needs to be refreshed every minute,
# based on whether new data is received or motion is detected. (Thanks @paviro!)
time:
  - platform: homeassistant
    timezone: Europe/Amsterdam
    on_time:
      - seconds: 0
        minutes: /1
        then:
          - if:
              condition:
                binary_sensor.is_on: motion_detected
              then:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-E1E44C"
    password: "SomeRandomPasswordThatShouldBeLong&Secure"
  reboot_timeout: 300s
#Include sun
sun:
  latitude: 52.0116
  longitude: 4.3571
# Include custom fonts
font:
  - file: 'fonts/GothamRnd-Book.ttf'
  - file: 'fonts/GothamRnd-Bold.ttf'
    glyphs: [' ', '°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C','.']
    #glyphs: [' ', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'M', 'I', 'N']
    # glyphs: ['°', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'C', 'M', 'I', 'N']
  - file: 'fonts/materialdesignicons-webfont.ttf'
    glyphs: &mdi-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
    glyphs: *mdi-glyphs
    glyphs: *mdi-glyphs
    glyphs: *mdi-glyphs
# Check if motion is detected in the Kitchen via Home Assistant.
binary_sensor:
    entity_id: binary_sensor.kitchen_sensor_motion
# Storage Sensors
    name: "Display Last Update"
    device_class: timestamp
    entity_category: "diagnostic"
    name: "Recorded Display Refresh"
    accuracy_decimals: 0
    unit_of_measurement: "Refreshes"
    state_class: "total_increasing"
    lambda: 'return id(recorded_display_refresh);'
# Home Assistant Weather
  # Air temperature - AccuWeather
    entity_id: weather.home
    attribute: temperature
  # Air pressure - AccuWeather
    attribute: pressure
text_sensor:
  # Weather State
    entity_id: weather.forecast_home
  # Sunrise
  - platform: sun
    type: sunrise
    format: "%H:%M"
  # Sunset
  - platform: sun
    type: sunset
    format: "%H:%M"
# Define colors
color:
  - id: color_black
    red: 0%
    green: 0%
    blue: 0%
    white: 50%
  - id: color_white
    red: 0%
    green: 0%
    blue: 0%
    white: 0%
# Pins for Waveshare ePaper ESP Board
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO14
# Now render everything on the ePaper screen.
display:
  - platform: waveshare_epaper
    cs_pin: 15
    busy_pin:
      number: 25
      inverted: true
    reset_pin: 26
    dc_pin: 27
    model: 7.50inV2alt
    update_interval: never
    rotation: 90°
    auto_clear_enabled: false
    reset_duration: 2ms
    lambda: |-
      // Map weather states to MDI characters.
      std::map<std::string, std::string> weather_icon_map
          {"cloudy", "\U000F0590"},
          {"cloudy-alert", "\U000F0F2F"},
          {"cloudy-arrow-right", "\U000F0E6E"},
          {"fog", "\U000F0591"},
          {"hail", "\U000F0592"},
          {"hazy", "\U000F0F30"},
          {"hurricane", "\U000F0898"},
          {"lightning", "\U000F0593"},
          {"lightning-rainy", "\U000F067E"},
          {"night", "\U000F0594"},
          {"night-partly-cloudy", "\U000F0F31"},
          {"partlycloudy", "\U000F0595"},
          {"partly-lightning", "\U000F0F32"},
          {"partly-rainy", "\U000F0F33"},
          {"partly-snowy", "\U000F0F34"},
          {"partly-snowy-rainy", "\U000F0F35"},
          {"pouring", "\U000F0596"},
          {"rainy", "\U000F0597"},
          {"snowy", "\U000F0598"},
          {"snowy-heavy", "\U000F0F36"},
          {"snowy-rainy", "\U000F067F"},
          {"sunny", "\U000F0599"},
          {"sunny-alert", "\U000F0F37"},
          {"sunny-off", "\U000F14E4"},
          {"sunset", "\U000F059A"},
          {"sunset-down", "\U000F059B"},
          {"sunset-up", "\U000F059C"},
          {"tornado", "\U000F0F38"},
          {"windy", "\U000F059D"},
          {"windy-variant", "\U000F059E"},
      // Fill background in white.
      it.fill(color_white);
      // ---- PRINT DAY + WEEK + MONTH ----------------------------------------------------
      it.strftime(25, 50, id(font_weekday), TextAlign::TOP_LEFT, "%A", id(homeassistant_time).now());
      it.strftime(333, 50, id(font_weekday), TextAlign::TOP_CENTER, "%d", id(homeassistant_time).now());
      it.strftime(465, 50, id(font_weekday), TextAlign::TOP_RIGHT, "%b", id(homeassistant_time).now());
      // --HORIZONTAL LINE-----------------------------------------------------------------
      it.rectangle(20, 110, 700, 1); //TOP
      // --- TEMPERATURE --------------------------------------------------------------------
        if(id(weather_temperature).has_state ()) {
            it.printf(25, 130, id(font_large_bold), color_black, TextAlign::TOP_LEFT, "%2.1f°C", id(weather_temperature).state);
      it.rectangle(20, 675, 710, 1); //ABOVE FOOTER
      // ----SUNRISE & SUNSET----------------------------------------------------------------------
      it.printf(100, 698, id(header_small_bold), color_black, TextAlign::CENTER, "SUNRISE");
        if(id(sun_next_rising).has_state ()) {
            it.printf(45, 725, id(font_mdi_medium), color_black, TextAlign::CENTER_LEFT, "\U000F059C");
            it.printf(85, 725, id(font_small_bold), color_black, TextAlign::CENTER_LEFT, "%s", id(sun_next_rising).state.c_str());
      it.printf(410, 698, id(header_small_bold), color_black, TextAlign::CENTER, "SUNSET");
        if(id(sun_next_setting).has_state ()) {
            it.printf(465, 725, id(font_mdi_medium), color_black, TextAlign::CENTER_RIGHT, "\U000F059B");
            it.printf(425, 725, id(font_small_bold), color_black, TextAlign::CENTER_RIGHT, "%s", id(sun_next_setting).state.c_str());
      // ----Print update timestamp-----------------------------------------------------------------
      // Code by EnsconcE from https://community.home-assistant.io/t/esphome-show-time/348903
      char str[17];
      time_t currTime = id(homeassistant_time).now().timestamp;
      strftime(str, sizeof(str), "%H:%M", localtime(&currTime));
      it.printf(255, 790, id(font_small_book), TextAlign::BOTTOM_CENTER, "UPDATED %s", str);
captive_portal:
