Hi
Migrated to hassio, and mostly migrated everything across, however having some issue with the weather widget showing me an error
Hi
the name is changed in HA.
so you need to specify the used sensors as explained in the docs.
http://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html#weather
esspecially this line is important:
precip_type: sensor.dark_sky_precip
thanks for that, i dont want to read precip etc at all on my dashboard
on my dashboard i just want the temperature and the icon
how can i achieve this one? i have tried to amend the sensors config, but still seeing the error on my dashboard,do you know how to remove that?
you might want to try weather summary.
if i understand correct the precip isnt optional in the full weather widget.
