Hmm so I thought I would start adding back in small bits at a time
I had some Synology cameras working.
But now they are unreachable?
Basic config +
camera:
- platform: synology
url: https://172.xx.0.xx:5001/
username: camusername
password: PassWord
verify_ssl: false
2020-04-02 18:38:35 ERROR (MainThread) [homeassistant.components.synology.camera] Error when initializing SurveillanceStation
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
OSError: [Errno 113] Host is unreachable
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 300, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f41baddbe50>: Failed to establish a new connection: [Errno 113] Host is unreachable
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='172.16.0.46', port=5001): Max retries exceeded with url: //webapi/query.cgi?api=SYNO.API.Info&method=Query&version=1&query=SYNO.API.Auth%2CSYNO.SurveillanceStation.Camera%2CSYNO.SurveillanceStation.Camera.Event%2CSYNO.SurveillanceStation.VideoStream (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f41baddbe50>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
File "/usr/src/homeassistant/homeassistant/components/synology/camera.py", line 53, in async_setup_platform
timeout=timeout,
File "/usr/local/lib/python3.7/site-packages/synology/surveillance_station.py", line 12, in __init__
self._api = Api(url, username, password, timeout, verify_ssl)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 59, in __init__
self._initialize_api_info()
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 70, in _initialize_api_info
payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 192, in _get_json_with_retry
return self._get_json(url, payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 198, in _get_json
response = self._get(url, payload)
File "/usr/local/lib/python3.7/site-packages/synology/api.py", line 185, in _get
verify=self._verify_ssl)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
But…???
# docker exec -it home-assistant /bin/bash
bash-5.0# wget https://172.xx.0.xx:5001/ --no-check-certificate -O -
Connecting to 172.xx.0.xx:5001 (172.xx.0.xx:5001)
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=11" />
<meta name="msapplication-TileImage" content="resources/images/icon_tile.png?v=4398" />
<meta name="application-name" content="nas1 - Synology DiskStation" />
<meta name="msapplication-TileColor" content="#246BB3"/>
<meta name="description" content="DiskStation provides a full-featured network attached storage (NAS) solution to help you manage, backup and share data among Windows, Mac and Linux easily." />
<meta name="keywords" content="Multitasking,Web Application,Personal Cloud" />
