Hello everyone,
I am trying to build a weather regulator for a mixing valve (3-way) of water.
Components connected to ESP12:
- The regulator has two temperature sensors, one to measure the external temperature, the other to measure the water temperature behind the mixer.
- The regulator has two relays, one responsible for controlling the mixer in a clockwise direction, the other for controlling the mixer in a counter-clockwise direction.
Principle of operation:
- On the basis of the external temperature and the selected heating curve, the water temperature behind the mixing valve is calculated.
- The measured temperature behind the mixing valve is compared with the calculated temperature (point 1). If the measured temperature behind the valve is lower, then the relay switches on for a specified time, which opens the valve (CW). If the measured temperature behind the valve is higher, it activates the relay for a certain time, which closes the valve (CCW). Opening or closing is to take place at certain intervals for a certain period of time. For example, the relay is closed for 2s every 60s.
I wrote sample code in YML on ESPHome, but it doesn’t quite work as I want and I can’t do some things. All code below.
globals:
- id: valveopening
type: int
restore_value: no
initial_value: '0'
- id: curve
type: float
restore_value: no
initial_value: '0.4'
- id: tmixer
type: float
restore_value: yes
dallas:
pin: GPIO16
update_interval: 10s
- platform: dallas
address: 0xdb3c01e07607f328
name: "Temp External"
- platform: dallas
address: 0x183c01e076081428
name: "Temp Behind the Mixer"
unit_of_measurement: "°C"
accuracy_decimals: 0
lambda: |-
return static_cast<int>(id(tempmixer).state);
name: "Mix Temperature Set"
lambda: |-
int t_external = static_cast<int>(id(tempexternal).state);
float t_mixer;
t_mixer = id(curve) * ( 20 - t_external ) + 20;
return static_cast<int>(t_mixer);
unit_of_measurement: "%"
icon: mdi:valve
lambda: |-
if( id(tempbehindmixer).state < id(mixtemperatureset).state ){
if(id(valveopening) >= 0 && id(valveopening) < 120){
id(valveopening) = id(valveopening) + 2;
id(cw).turn_on();
delay(id(tmixer) * 1000);
id(cw).turn_off();
}else if( id(tempbehindmixer).state > id(mixtemperatureset).state ){
if(id(valveopening) <= 120 && id(valveopening) > 0){
id(valveopening) = id(valveopening) - 2;
id(ccw).turn_on();
id(ccw).turn_off();
}else id(valveopening) = id(valveopening);
return id(valveopening);
switch:
- platform: gpio
pin: GPIO13
inverted: True
- platform: gpio
pin: GPIO12
inverted: True
number:
name: "Mixer Pulse Time"
optimistic: True
min_value: 0
max_value: 20
step: 0.5
on_value:
then:
- globals.set:
value: !lambda |-
return id(tmixer) = x;
name: "Mixer Pulse Period"
optimistic: True
min_value: 20
max_value: 120
step: 0.5
optimistic: True
min_value: 0.1
max_value: 1
step: 0.1
The code in the “Mixer Control” section works as I want and shows me the value of valve opening in %. But rather it must be included differently than in the sensor template, because in this case I can’t set the period at which the opening or closing of the valve should work. I am asking for hints on how to do it right, where to put the code so that it works independently. I hope you can do it in another simple way without writing code in C++ and take full advantage of ESPHome.
I have created a number template with which I will set the values I need and then they will be used in the code for calculations and setting the mixer. I know how to make this value from the number template go to the globals variable. I have an example done in “Mixer Pulse Time”. I still need these values to be saved in the ESP12 memory when the power supply is disconnected and then the number template values set to those values from the ESP12 memory that were set earlier. I try different settings but each time it either doesn’t work or ESP12 crashes.
Please help, advice and questions, I will describe the problem in detail.
