Hi, i’ve started a new project for intercept the updates sent from any weather station to Weather Underground and publish the data trough mqtt on Home Assistant, so the device become “local” and near real-time (updates every 30 sec, depend from the device).
Here the link, feel free to help as i’m really newby on coding.
Hi, Yes i know that software. Mine Is Just a script in python of few line of code for a very specific porpuse (serve home assistant), so less stuffs to run over home assistant!
You have successuffully redirect http traffic coming from the station to the hass ip? Check in the log of the plugin if you see the packet coming, let me know.
Exception occurred during processing of request from (‘192.168.0.99’, 32676)
File “/usr/lib/python3.11/socketserver.py”, line 317, in handle_request_noblock
self.process_request(request, client_address)
File “/usr/lib/python3.11/socketserver.py”, line 348, in process_request
self.finish_request(request, client_address)
File “/usr/lib/python3.11/socketserver.py”, line 361, in finish_request
self.RequestHandlerClass(request, client_address, self)
File “/usr/lib/python3.11/http/server.py”, line 667, in init
super().init(*args, **kwargs)
File “/usr/lib/python3.11/socketserver.py”, line 755, in init
self.handle()
File “/usr/lib/python3.11/http/server.py”, line 432, in handle
self.handle_one_request()
File “/usr/lib/python3.11/http/server.py”, line 420, in handle_one_request
method()
File “/pws_server.py”, line 143, in do_GET
publish(client, MQTT_TOPIC + “/low_battery”, (MyHttpRequestHandler.parse_wu_data(query_components)['Low_battery[]’]) )
KeyError: ‘Low_battery_[]’
Found the problem, the script expect also the filed “lowbatt” while it’s not present in your string, it should be after “baromin”.
You have two option:
1- manually enter the addon folder and change the pws_server.py and remove the reference to lowbatt publishing, line 142
2- fork my project and do the same
Wow, I really like this addon solution. Used it for a Bresser WSX3001. Had to make some small changes in pws_server.py (disable rain_weekly, rain_monthly, rain_yearly, temperature_in, humidity_in, low_battery). But further It works great.
In the AP mode of the Bresser you could add the URL and port of your addon.
Maybe it could be improved to have MQTT discovery and the MQTT credentials via the addon configuration.
Thank for your message, I added the config for ip,port,user,pwd for now…
for update you have to stop the addon, save your personal config for bakup and uninstall.
Then proceed with a new installation with the new folder on github.
I’m not a coder, so someone else can do a better job for sure forking the project
Hey, sorry to revive an old thread. I’ve got a weather station that either lets you enter WeatherUnderground credentials, or WeatherCloud credentials. There’s no way to set a local IP address etc to redirect the data to Home Assistant unfortunately.
Would this add-on still be able to intercept the data from the weather station, or does it require that the weather station has the ability to send the data somewhere on your local network?
If nothing has changed in the WeatherUnderground protocol, it should work without any issues. Weather stations upload data to WeatherUnderground by sending an HTTP link containing all the data separated by commas. You simply need to intercept this packet and forward it to the address where the addon is running. Therefore, you just need to create a forwarding rule on the router that identifies everything coming from the weather station’s IP address on port 80 and redirects it to the addon on port 80.
Thanks, that’s what I thought, appreciate the confirmation!
I’ve tried setting up both port forwarding and a NAT rule in my router (Unifi) but neither of them seem to result in any data getting through to HA.
All I get up to in the Weather Station to MQTT logs is the startup sequence and then running pws server and no further log items, no matter how long I leave it running for.
I’ll need to do some more digging to find out why the data isn’t making it over to HA
check your nat rule and sniff packet at firewall level coming from the weather station. The http packet was uncrypted and clearly visible. Could be that on newer station WU use encrypted https connections, in this case there’s nothing we can do.
