Weather station modified with an ESP32
Here is my weather station project. This is a cheap wireless weather station I modified with an ESP32 & programmed with the wonderful ESPHome.
I choose to completely remove the original electronics because I wanted to receive data from the sensors at a shorter interval and I can’t be bothered decoding the wireless signal sent.
This is the cheap weather station I purchased. I will not be using the battery powered LCD display.
Weaknesses of this weather station is construction quality.
The metal stand is not stainless steel, nor galvanised or aluminium.
The plastic sensors are likely to breakdown in sunlight UV (as I have seen on another unit).
I painted the sensor units with outdoor rated white spray paint.
The sensors;
Anemometer (Wind speed)
This is a wind cup anemometer and the number of rotations per time period can be used to calculate wind speed.
I found this unit has a magnetic reed switch and a magnet. Two pulses are given per full rotation of the wind cups.
Bearing direction (Wind vane)
This uses 4 magnetic reed switches, for North, East, South & West.
When pointed North, the North reed switch closes and connects a resistor in parallel to the sensor’s wires.
Each direction has a different resistance per direction.
Directions between, e.g. North East, are the resistance value of two resistors in parallel.
I can’t remember off the top of my head what the resistor values were. I connected the sensor across a voltage divider and used an ADC sensor. Value ranges of the ADC correlated to a direction.
Rain gauge
This is a tipping bucket rain gauge. Rain water falls into a funnel and feels a small bucket. When the bucket fills with water it tips over under gravity and activates a magnetic reed switch. The count of bucket tips is the measured rain.
This rain gauge is 0.3mm per bucket tip.
Temperature + Humidity
I removed the original temperature sensor and utilised a DHT22 sensor.
esphome:
  friendly_name: weather_station_esp32
esp32:
  board: esp32dev
  framework:
    type: arduino
#Buch of stuff here.
#Pinouts:
  #DHT22 - 18/D18
  #Anemometer - 32/D32
  #Wind direction - 34/D34
  #Rain gauge - 33/D33
button:
    name: "Reset total rain"
    icon: "mdi:rotate-left"
    on_press:
      - pulse_counter.set_total_pulses:
          value: !lambda 'return 0;'
  # DHT temp + humidity sensor
  - platform: dht
    pin: GPIO18
    model: DHT22
    temperature:
      name: "Station Temperature"
      filters:
        filter_out: nan
    humidity:
      name: "Station Humidity"
      filters:
        filter_out: nan
    update_interval: 120s
  - platform: absolute_humidity
    name: Station Absolute Humidity
    temperature: stationtemperature
    humidity: stationhumidity
    filters:
      filter_out: nan
  # Wind anemometer
  # 2 Pules per rotation
  - platform: pulse_counter
    name: Station Wind Speed
    pin:
      number: GPIO32
      inverted: true
      mode:
        input: true
        pullup: true
    update_interval: 10s
    filters:
      - lambda: if (x < 0.001) return x; else return 1.761 / (1 + (x / 2 * 0.02010619298) ) + 3.013 * (x / 2 * 0.02010619298);
      - sliding_window_moving_average:
          window_size: 12
          send_every: 6
    unit_of_measurement: 'Km/h'
    device_class: wind_speed
    on_value:
      then:
        - component.update: stationknots
  #Km/h to knots
    name: Station wind speed knots
    lambda: |-
      return id(stationwindspeed).state * 0.53996;
    unit_of_measurement: 'knt'
  # Feels like temperature
    name: "Feels Like Temperature"
    unit_of_measurement: '°C'
    filters:
      filter_out: nan
    lambda: |-
      float T = id(stationtemperature).state;  // Replace with your temperature sensor
      float RH = id(stationhumidity).state;  // Replace with your humidity sensor
      float WS = id(stationwindspeed).state;  // Replace with your wind speed sensor
      float HI;
      T = T * 9/5 + 32;  // Convert temperature from Celsius to Fahrenheit for the formula
      if (T < 80.0) {
        HI = 0.5 * (T + 61.0 + ((T-68.0)*1.2) + (RH*0.094));
      } else {
        HI = -42.379 + 2.04901523*T + 10.14333127*RH - 0.22475541*T*RH - 6.83783*pow(10,-3)*pow(T,2) - 5.481717*pow(10,-2)*pow(RH,2) + 1.22874*pow(10,-3)*pow(T,2)*RH + 8.5282*pow(10,-4)*T*pow(RH,2) - 1.99*pow(10,-6)*pow(T,2)*pow(RH,2);
        if (RH < 13 && T >= 80 && T <= 112) {
          float adjust = ((13-RH)/4) * sqrt((17-abs(T-95))/17);
          HI -= adjust;
        } else if (RH > 85 && T >= 80 && T <= 87) {
          float adjust = ((RH-85)/10) * ((87-T)/5);
          HI += adjust;
      return (HI - 32) * 5/9;  // Convert back to Celsius
  #Rain gauge
    pin:
      number: GPIO33
      inverted: true
      mode:
        pullup: true
        input: true
    unit_of_measurement: 'mm/min'
    update_interval: 60s
    accuracy_decimals: 1
    filters:
      - debounce: 0.05s
      - multiply: 0.3  # pulses x 0.3mm
    total:
      unit_of_measurement: 'mm'
      name: 'Station Total Rain'
      filters:
        - multiply: 0.3
  #Wind direction
  - platform: adc
    name: "Station Wind Dir"
    internal: true
    pin: 34
    accuracy_decimals: 0
    unit_of_measurement: 'ADC'
    raw: true
    filters:
      - multiply: 1.0
      - median:
          window_size: 6
          send_every: 6
          send_first_at: 1
    name: "Station Wind Direction bearing"
    unit_of_measurement: '°'
    lambda: |-
      if (id(station_winddirection).state > 1500 && id(station_winddirection).state <= 1700) {
        return 90.0; //North - offset to west
      else if (id(station_winddirection).state > 650 && id(station_winddirection).state <= 800) {
        return 135.0; //North East
      else if (id(station_winddirection).state > 900 && id(station_winddirection).state <= 1100) {
        return 180.0; //East
      if (id(station_winddirection).state > 800 && id(station_winddirection).state <= 900) {
        return 225.0; //South East
      if (id(station_winddirection).state > 1900 && id(station_winddirection).state <= 2300) {
        return 270.0; //South
      if (id(station_winddirection).state > 1700 && id(station_winddirection).state <= 1900) {
        return 315.0; //South West
      if (id(station_winddirection).state > 2300 && id(station_winddirection).state <= 2500) {
        return 0.0; //West
      if (id(station_winddirection).state > 1100 && id(station_winddirection).state <= 1500)  {
        return 45.0; //North West
      else {
        return 345.0; //Fault
This is an ESP32 module from AliExpress.
On the circuit board is terminal connectors, a power switch, 12v to 5v buck step down module and an LDR’s pcb. I have an LDR for light levels but never calibrated it (still does alright to schedule garden lights).
The station itself is mounted to my TV antenna on the back of my house. Power cables runs under a roof tile and is connected in a cupboard to a 12v PSU.
Some cool features in this project;
I added a “feels like” temperature. This factors the temperature, humidity and wind speed.
    filters:
      filter_out: nan
    lambda: |-
      float HI;
      if (T < 80.0) {
      } else {
          HI -= adjust;
          HI += adjust;
I also log the max, median and minimum of each sensor to a Google spreadsheet at midnight every night.
This is done with an automation and helper sensors.
Google sheets then makes a lovely graph I can use. There’s also other sensors I log daily into Google sheets as you can see by the sheet tabs.
I haven’t found a good way to log wind vane direction yet.
A small addition.
I have figured a way to log the wind vane per day, without needing an hourly measurement (e.g. North at 12pm, East at 1pm).
What I have done is used a history_stats helper to count how many hours the wind vane is aiming in a direction over 24hrs/1 day.
This count is added to a Google sheet at midnight (bottom right graph).
This photo also shows the other sensors graphs since I started long-term logging to Google sheets.
Google sheets also offers ‘publishing’ a graph and embedding it into a webpage which is awesome!
How is it holding up?
It’s been doing great. I haven’t needed to climb a ladder and check it.
A modification I would like to make in ESPhome Code is for a wind gust measurement. Currently all the wind calculations is a sliding window average.
Data logging to Google Sheets is now over 1 year.
A few failed API requests to Google sheets occasionally, but I have backup local CSV file to copy missing data.
Awesome, appreciated.
As fun as the project looks and I <3 ESP I’m going with the OMG option for now. It was very simple.
Such a nicely done project. I’m looking to do the same. Would you mind sharing your code for that dashboard? I would love to try something similar
There’s a mix of card types here.
Compass card is visual editor to add. Requires wind vane to be in numerical degrees values output.
Windrose card also requires wind vane in numerical degrees value.
Temperature, humidity, wind speed & rain is Mini-graph card.
Here’s the code for temperature:
type: custom:mini-graph-card
hours_to_show: 24
points_per_hour: 5
line_width: 2
icon: mdi:home
hour24: true
animate: true
entities:
  - entity: sensor.weather_station_esp32_station_temperature
    show_state: true
  - entity: sensor.weather_station_esp32_feels_like_temperature
    show_state: true
  - entity: sensor.weather_station_esp32_wind_chill
    show_state: true
    show_fill: false
    show_line: false
    show_points: false
    show_legend: true
show:
  extrema: true
  average: true
  fill: fade
  icon: false
  labels: hover
color_thresholds:
  - value: 0
    color: "#00A3FF"
  - value: 15
    color: "#00D084"
  - value: 20
    color: "#FF6900"
  - value: 25
    color: "#FF0000"
Here is the code for rain card today, only the time between midnight to now() is shown.
type: custom:config-template-card
entities:
  - sensor.rain_daily
card:
  hours_to_show: |-
      var date = new Date();
      var curHour = date.getHours() + date.getMinutes()/60.0 + date.getSeconds()/3600.0;
      curHour
  points_per_hour: 5
  line_width: 2
  icon: mdi:home
  hour24: true
  entities:
    - entity: sensor.rain_daily
      show_state: true
      unit: mm
      color: cyan
  show:
    extrema: false
    average: false
    fill: fade
    icon: false
    labels: hover
This is the bar chart rain in the last 24 hours.
hours_to_show: 24
points_per_hour: 2
line_width: 2
icon: mdi:home
hour24: true
entities:
  - entity: sensor.weather_station_esp32_station_rain
    show_state: true
    color: cyan
show:
  extrema: true
  average: false
  fill: fade
  icon: false
  labels: hover
  graph: bar
The windrose card code:
I choose to use km/h instead of Beaufort measurement.
type: custom:windrose-card
title: Wind - 24 hour
show_current_direction_arrow: true
corner_info:
  top_left:
    label: Current windspeed
    unit: " km/h"
    entity: sensor.weather_station_esp32_station_wind_speed
data_period:
  hours_to_show: 24
max_width: 400
refresh_interval: 60
windspeed_bar_location: bottom
windspeed_bar_full: true
wind_direction_entity:
  entity: sensor.weather_station_esp32_station_wind_direction_bearing
  direction_unit: degrees
  use_statistics: false
  direction_compensation: 0
windspeed_entities:
  - entity: sensor.weather_station_esp32_station_wind_speed
    speed_unit: kph
    use_statistics: true
output_speed_unit: kph
input_speed_unit: kph
speed_range_beaufort: false
windrose_draw_north_offset: 0
cardinal_direction_letters: NESW
matching_strategy: direction-first
center_calm_percentage: false
speed_range_max: 25
speed_range_step: 2
colors:
  rose_lines: grey
  rose_direction_letters: Grey
  rose_percentages: grey
  bar_border: hsl(200, 100%, 60%)
  bar_unit_name: grey
  bar_name: grey
  bar_unit_values: bar
  bar_percentages: black
Horizon card:
type: custom:horizon-card
time_zone: Pacific/Auckland
time_format: 24
southern_flip: false
Update:
I have changed the wind speed code to be a raw pulse counter, then use template sensors for gust, average and knots.
Before I had a sliding window average within the pulse counter measurement.
Now I have added a pulse counter which is internal, then wind gust, average & knots is calculated off of this.
The wind gust and wind knots sensor publishes to Home Assistant each time the wind average sensor publishes on a 1min interval. In the code this is on_value: - component.update: station_wind_gust.
  # Raw pulse_counter for wind gust tracking
    name: "Station Wind Gust (Raw)"
    internal: True
    pin:
      number: GPIO32
      inverted: true
      mode:
        input: true
        pullup: true
    update_interval: 5s
    unit_of_measurement: 'pulses/s'
    on_value:
      then:
        - lambda: |-
            float wind_kph = (x < 0.001) ? x : 1.761 / (1 + (x / 2 * 0.02010619298) ) + 3.013 * (x / 2 * 0.02010619298);
            unsigned long now = millis();
            if (now - id(wind_gust_last_reset) > 120000) {
              id(wind_gust_kph) = wind_kph;
              id(wind_gust_last_reset) = now;
            } else if (wind_kph > id(wind_gust_kph)) {
  # Gust value (based on raw input)
    name: "Station Wind Gust"
    unit_of_measurement: 'km/h'
    state_class: measurement
    update_interval: never
    lambda: 'return id(wind_gust_kph);'
  # Averaged wind speed for normal reporting
    name: "Station Wind Speed"
    lambda: |-
      float wind_kph = (id(stationwindgust_raw).state < 0.001) ? id(stationwindgust_raw).state :
                      1.761 / (1 + (id(stationwindgust_raw).state / 2 * 0.02010619298) ) +
                      3.013 * (id(stationwindgust_raw).state / 2 * 0.02010619298);
      return wind_kph;
    filters:
          window_size: 12
          send_every: 6
    on_value:
  #Km/h to knots
    lambda: |-
killer work mate.
I moved to a new house and it has a unit just like the one you have.
using your code I can get wind speed and rain.
direction is not working but I will work that out.
So thank you for shearing.
Thankyou.
Rain detection is a tipping bucket. In 0.3mm amounts per tip.
It is a binary sensor with a reed switch. Debounce & pull up (or pull down) resistor is needed.
On most esp32 pins you can enable pull up/down through code, other pins need a resistor physically soldered in.
Daily, weekly & yearly totals are statistics helpers in Home Assistant.
Nice project, love the setup!
Hello Mark,
I just found your project I am under construction of the same, with exactly the same Weatherstation,
Do you have a picture how you connected the wind direction reed contacts to the ads ?
Is myapproach right ?
To be honest I have verry smal experience in yamml, I will just copy yours with adaption.
Thanks Frank
There’s two output wires from the wind bearing (direction) sensor.
Inside of my one is 4 reed switches and a resistor in series. These 4 are wired in parallel. Some have 8 reed switches & resistors. With the benefit of 16 directions instead of 8 able to be measured.
I measure this between GND - Analogue In, with a pull-up resistor of 10k.
Measure your wind direction sensor’s resistance using a multi-meter. Spin it by hand and hold in N / NE / E / SE / S / SW / W / NW directions and write down the resistance.
Use a voltage divider calculator, I did mine in a spreadsheet.
Measuring resistance before wiring up a voltage divider helps to choose the correct pull-up resistor value.
You could measure N / E / S / W resistances and do a parallel resistor calculation for NE / SE / NW / SW… but measuring is easier.
Importantly:
The ESPhome code for the ADC value is a range. E.g. North position <=1700 >1500.
Cable changes resistance slightly by temperature changes. It’ll never be accurate detecting on a fixed value e.g. =1650.
Thank you Mark
I took this values for north,east,west,south
The subvalues are calculated.
The voltage is at pin 34 i measured mostly that. Vollt below.
I fear I killed the input, as I first connected it to 5v
I come back.
  Ohm. Volt.  Digitalcounter
N r1 6.800 1,336 1658
E r2 3.300 0,819 1016
S r3 12.000 1,800 2234
W r4 22.000 2,269 2815
NE. 2.222 0,600 744
NW 4.340 0,999 1239
SE 2.588 0,679 842
SW. 7.765 1,442 1790
R5 10.000
I moved the win direction to pin 35, but the direction does not work.
What are these ‘digital counter’ values?
I got it working
R5 10k
R1 1,2k North. Digit Value 1112
R2 0,7K east. 560
R3 2,2 k south. 2128
R4 3,3k west. 3028
Last numbers are the digital values of the adc input
and this are the vallues i used in the code, it works great
 platform: template
    lambda: |-
      if (id(station_winddirection).state > 939 && id(station_winddirection).state <= 1188) {
        return 0.0; //North
      else if (id(station_winddirection).state > 150 && id(station_winddirection).state <= 293) {
        return 45.0; //North East
      else if (id(station_winddirection).state > 449 && id(station_winddirection).state <= 662) {
        return 90.0; //East
      if (id(station_winddirection).state > 294 && id(station_winddirection).state <= 448) {
        return 135.0; //South East
      if (id(station_winddirection).state > 1693 && id(station_winddirection).state <= 2574) {
        return 180.0; //South
      if (id(station_winddirection).state > 1189 && id(station_winddirection).state <= 1692) {
        return 225.0; //South West
      if (id(station_winddirection).state > 2575 && id(station_winddirection).state <= 3200) {
        return 270.0; //West
      if (id(station_winddirection).state > 663 && id(station_winddirection).state <= 938)  {
        return 315.0; //North West
      else {
now i just struggle at two graphical views.
what is the best way to get a statistic graph in the dashboard, to see the rain per day, in a bar for the last 7 days,. the integration makes … when i reset,
thanks Frank
There’s some great historical graphing ideas in a parallel thread - see ☔ DIY Zigbee rain gauge.
