if you have split out sensors into their own YAML file, yes.
Otherwise they would go into configuration.yaml
I made some slight modifications to your example and it worked!
When I initially got everything working the naming scheme was âcotech_376959_121_wsâ and so on. I renemed the device to âWeather Stationâ and it updated everything like: sensor.weather_station_ws
Iâve also included a conversion for rain from mm to inches
sensors:
weather_station_wind_mph:
friendly_name: "Wind Speed Miles per Hour"
unique_id: "Wind Speed MPH"
value_template: "{{ (states('sensor.weather_station_ws') | float(0.0) | round(1) * 0.6213712) | round(1) }}"
unit_of_measurement: 'mph'
weather_station_gust_mph:
friendly_name: "Gust Speed Miles per Hour"
unique_id: "Gust Speed MPH"
value_template: "{{ (states('sensor.weather_station_gs') | float(0.0) | round(1) * 0.6213712) | round(1) }}"
wind_dir_abbrev:
friendly_name: "Wind Direction Abbrev"
unique_id: "Wind Direction Abbrev"
value_template: >-
{% set degrees = states('sensor.weather_station_wd') | int %}
{% if degrees >= 0 and degrees <= 11 %}
North
{% elif degrees >= 12 and degrees <= 33 %}
North-Northeast
{% elif degrees >= 34 and degrees <= 56 %}
Northeast
{% elif degrees >= 57 and degrees <= 78 %}
East-Northeast
{% elif degrees >= 79 and degrees <= 101 %}
East
{% elif degrees >= 102 and degrees <= 123 %}
East-Southeast
{% elif degrees >= 124 and degrees <= 146 %}
Southeast
{% elif degrees >= 147 and degrees <= 168 %}
South-Southeast
{% elif degrees >= 169 and degrees <= 191 %}
South
{% elif degrees >= 192 and degrees <= 213 %}
South-Southwest
{% elif degrees >= 214 and degrees <= 236 %}
Southwest
{% elif degrees >= 237 and degrees <= 258 %}
West-Southwest
{% elif degrees >= 259 and degrees <= 281 %}
West
{% elif degrees >= 282 and degrees <= 303 %}
West-Northwest
{% elif degrees >= 304 and degrees <= 326 %}
Northwest
{% elif degrees >= 327 and degrees <= 348 %}
North-Northwest
{% elif degrees >= 349 and degrees <= 359 %}
North
{% else %}
{% endif %}
weather_station_rain_in:
friendly_name: "Rainfall Inches"
unique_id: "Rainfall Inches"
value_template: "{{ (states('sensor.weather_station_rt') | float(0.0) | round(2) * 0.0393701) | round(2) }}"
unit_of_measurement: 'in'
Congratulations!!!
Now, for rainfall there are utility_meter
items that can provide daily, weekly, monthly, and annual measurements. Here is what i have so far, but I havenât yet worked out the proper decimal placement for accurate measurements.
# Utility Meter
# Used with the weather station for periodic measurements
utility_meter:
rainfall_mm_daily:
source: sensor.cotech_367959_121_rain_mm
unique_id: rainfall_daily_mm
name: 'Rainfall Today Millimeters'
cycle: daily
rainfall_mm_weekly:
unique_id: rainfall_weekly_mm
name: 'Rainfall Weekly Millimeters'
cycle: weekly
rainfall_mm_monthly:
unique_id: rainfall_monthly_mm
name: 'Rainfall Monthly Millimeters'
cycle: monthly
rainfall_mm_yearly:
unique_id: rainfall_yearly_mm
name: 'Rainfall Yearly Millimeters'
cycle: yearly
rainfall_in_daily:
friendly_name: "Rainfall Today Inches"
device_class: 'precipitation'
value_template: >-
{{ states('sensor.rainfall_today_millimeters_2') | float(0.0) * 0.3937 }}
rainfall_in_weekly:
friendly_name: "Rainfall Weekly Inches"
value_template: >-
{{ states('sensor.rainfall_weekly_millimeters') | float(0.0) * 0.3937 }}
rainfall_in_monthly:
friendly_name: "Rainfall Monthly Inches"
value_template: >-
{{ states('sensor.rainfall_monthly_millimeters') | float(0.0) * 0.3937 }}
rainfall_in_yearly:
friendly_name: "Rainfall Annual Inches"
value_template: >-
{{ states('sensor.rainfall_yearly_millimeters') | float(0.0) * 0.3937 }}
Maybe this one?
utility_meter:
rainfall_mm_daily:
cycle: daily
rainfall_mm_weekly:
cycle: weekly
cycle: monthly
rainfall_mm_yearly:
cycle: yearly
sensors:
rainfall_in_daily:
value_template: >-
{{ states('sensor.rainfall_mm_daily') | float(0.0) * 0.0393701 }}
rainfall_in_weekly:
value_template: >-
{{ states('sensor.rainfall_mm_weekly') | float(0.0) * 0.0393701 }}
value_template: >-
{{ states('sensor.rainfall_mm_monthly') | float(0.0) * 0.0393701 }}
rainfall_in_yearly:
value_template: >-
{{ states('sensor.rainfall_mm_yearly') | float(0.0) * 0.0393701 }}
or rounded to 2 decimals:
utility_meter:
rainfall_mm_daily:
cycle: daily
rainfall_mm_weekly:
cycle: weekly
cycle: monthly
rainfall_mm_yearly:
cycle: yearly
sensors:
rainfall_in_daily:
value_template: >-
{{ (states('sensor.rainfall_mm_daily') | float(0.0) * 0.0393701) | round(2) }}
rainfall_in_weekly:
value_template: >-
{{ (states('sensor.rainfall_mm_weekly') | float(0.0) * 0.0393701) | round(2) }}
value_template: >-
{{ (states('sensor.rainfall_mm_monthly') | float(0.0) * 0.0393701) | round(2) }}
rainfall_in_yearly:
value_template: >-
{{ (states('sensor.rainfall_mm_yearly') | float(0.0) * 0.0393701) | round(2) }}
Hereâs the one Iâm using now:
sensors:
wind_dir_abbrev:
value_template: >-
North
North-Northeast
Northeast
East-Northeast
East
East-Southeast
Southeast
South-Southeast
South
South-Southwest
Southwest
West-Southwest
West
West-Northwest
Northwest
North-Northwest
North
{% else %}
{% endif %}
#### conversion of rain from mm to in for utility meter tracking ###
sensors:
rainfall_in_daily:
unique_id: "rainfall_in_daily"
value_template: "{{ (states('sensor.rainfall_today_millimeters') | float(0.0) * 0.0393701) | round(2) }}"
rainfall_in_weekly:
unique_id: "rainfall_in_weekly"
value_template: "{{ (states('sensor.rainfall_weekly_millimeters') | float(0.0) * 0.0393701) | round(2) }}"
unique_id: "rainfall_in_monthly"
value_template: "{{ (states('sensor.rainfall_monthly_millimeters') | float(0.0) * 0.0393701) | round(2) }}"
rainfall_in_yearly:
unique_id: "rainfall_in_yearly"
value_template: "{{ (states('sensor.rainfall_yearly_millimeters') | float(0.0) * 0.0393701) | round(2) }}"
utility_meter:
rainfall_mm_daily:
source: sensor.weather_station_rt
cycle: daily
rainfall_mm_weekly:
cycle: weekly
cycle: monthly
rainfall_mm_yearly:
cycle: yearly
Warning tip for others:
I had to replace the batteries in my weather station tonight, after over a year of solid performance. When I did so, the ID value changed from 121 to 0, which changed the MQTT topic ârtl_433/17069798-rtl433/devices[/type][/model][/subtype][/channel][/id]â. I had to edit all of my MQTT sensors and reload YAML files to get the data coming in again.
Can you expand on this? I have a greenhouse I want to incorporate. I am new and have not done any integrations with a RTL-SDR Blog V3 R860 RTL2832U 1PPM TCXO SMA Software Defined Radio
GW2000A from froggit without a cloud directly with restFUL try it as my_weather.yaml
The Router ist located in my local network over WLAN with own IP xxx.xxx
but it is always sunny In the moment itâs not perfect, but it grows up!
rest:
- authentication: basic
# username: "admin"
# password: "password"
scan_interval: 300
# curl -s http://192.168.xxx.xxx/get_livedata_info?
resource: http://192.168.xxx.xxx/get_livedata_info?
headers:
Content-Type: application/json
method: GET
- name: "Temperatur AuĂen"
value_template: "{{ value_json['common_list'][0]['val'] | default(0) | float(0) }}"
unit_of_measurement: "°C"
device_class: temperature
state_class: measurement
unique_id: temp_aussen
- name: "Luftfeuchte AuĂen"
value_template: "{{ value_json['common_list'][1]['val'][:-1] | default(0) | float(0) }}"
unit_of_measurement: "%"
device_class: humidity
unique_id: luftfeuchte_aussen
- name: "Temperatur 2"
value_template: "{{ value_json['common_list'][2]['val'] | default(0) | float(0) }}"
unique_id: temp_out2
- name: "Temperatur 3"
value_template: "{{ value_json['common_list'][3]['val'] | default(0) | float(0) }}"
unique_id: temp_out3
- name: "Temperatur 4"
value_template: "{{ value_json['common_list'][4]['val'] | default(0) | float(0) }}"
unique_id: temp_out4
- name: "Temperatur 5"
value_template: "{{ value_json['common_list'][5]['val'] | default(0) | float(0) }}"
unique_id: temp_out5
- name: "Wind geschwindigkeit"
value_template: "{{ value_json['common_list'][6]['val'][:-5] | default(0) | float(0) }}"
unit_of_measurement: "km/h"
device_class: wind_speed
unique_id: wind_geschwindigkeit
- name: "Wind 7"
value_template: "{{ value_json['common_list'][7]['val'][:-5] | default(0) | float(0) }}"
unique_id: wind7
- name: "Wind 8"
value_template: "{{ value_json['common_list'][8]['val'][:-5] | default(0) | float(0) }}"
unique_id: wind8
- name: "Solar"
value_template: "{{ value_json['common_list'][9]['val'][:-4] | default(0) | float(0) }}"
unit_of_measurement: "W/m²"
device_class: irradiance
unique_id: solar
- name: "UV Index"
value_template: "{{ value_json['common_list'][10]['val'] |int }}"
unit_of_measurement: "-"
unique_id: uv_index
- name: "Windrichtung"
value_template: "{{ value_json['common_list'][11]['val'] |int }}"
#value_template: >
# {% set direction = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSW','SW','WSW','W','WNW','NW','NNW','N'] %}
# {{ direction[(((value_json['common_list'][11]['val']| default(0) | float(0)) +11.25)/22.5)|int] }}
unique_id: windrichtung
- name: "Regenmenge Ereignis"
value_template: "{{ value_json['rain'][0]['val'][:-3] | default(0) | float(0) }}"
unit_of_measurement: "mm"
device_class: precipitation
unique_id: regenmenge_ereignis
- name: "Regenrate"
value_template: "{{ value_json['rain'][1]['val'][:-6] | default(0) | float(0) }}"
unit_of_measurement: "mm/Hr"
unique_id: Regenrate
- name: "Regenmenge täglich"
value_template: "{{ value_json['rain'][2]['val'][:-3] | default(0) | float(0) }}"
unique_id: regenmenge_taeglich
- name: "Regenmenge wĂśchentlich"
value_template: "{{ value_json['rain'][3]['val'][:-3] | default(0) | float(0) }}"
unique_id: regenmenge_woechentlich
- name: "Regenmenge monatlich"
value_template: "{{ value_json['rain'][4]['val'][:-3] | default(0) | float(0) }}"
unique_id: regenmenge_monatlich
- name: "Regenmenge jährlich"
value_template: "{{ value_json['rain'][5]['val'][:-3] | default(0) | float(0) }}"
unique_id: regenmenge_jaehrlich
- name: "Batterieentleerung"
value_template: "{{ value_json['rain'][5]['battery'] | default(0) | float(0) }}"
device_class: battery
unique_id: batterie
- name: "Temperatur innen"
value_template: "{{ value_json['wh25'][0]['intemp'] | default(0) | float(0) }}"
unique_id: temperatur_innen
- name: "Luftfeuchte innen"
value_template: "{{ value_json['wh25'][0]['inhumi'][:-1] | default(0) | float(0) }}"
unique_id: luftfeuchte_innen
- name: "Luftdruck abs"
value_template: "{{ value_json['wh25'][0]['abs'][:-4] | default(0) | float(0) }}"
unit_of_measurement: "hPa"
device_class: atmospheric_pressure
unique_id: luftdruck_abs
- name: "Luftdruck rel"
value_template: "{{ value_json['wh25'][0]['rel'][:-4] | default(0) | float(0) }}"
unique_id: luftdruck_rel
weather:
name: "Wetter Tomroden"
unique_id: tomroden_wetter
temperature_template: "{{ states('sensor.temp_aussen') | float(0.0) }}"
humidity_template: "{{ states('sensor.luftfeuchte_aussen') | float(0.0) }}"
pressure_template: "{{ states('sensor.luftdruck_abs') | float(0.0) }}"
wind_speed_template: "{{ states('sensor.wind_geschwindigkeit') | int(0) }}"
wind_bearing_template: "{{ states('sensor.windrichtung') | int(0) }}"
attribution_template: "{{ states('sensor.temp_aussen') | float(0.0) }}"
condition_template: "sunny"
Hi, I just bought Waldbeck Huygens 6 in 1. Itâs up and running, transmitting data to the base station. I got stuck connecting it via rtl_433.
According to the instruction, it transmits at 868MHz. Iâm running:
rtl_433 -f 868M -s 1024k
but Iâm not getting any reads. Any clue?
I tested the dongle by scanning 433MHz frequency and it reads eg my garage door remote, so I assume the dongle works, but why doesnât it read anything on 868MHz?
