Weather Station Sencor HA integration
Hi!
First post here, so please be gentle! :slight_smile: Is there a feature to integrate Sencor home weather station to HA? Its on wifi and sends information to Weather Underground. I saw, that there is a script for WU API, but if all is kept local, why should one use external weather reports?
I want to do this to monitor wind speeds. When getting stronger, my blinds should open completely because to prevent wind damage.
Thank you!
Hi Victor_b,
Have you investigated further?
I’m thinking of buying Sencor SWS 9898 but I would like to make sure it will work with HA.
Anyone know?
Apparently it works with „Weather Underground“ and „Weathercloud“ so it will perhaps work with HA at least indirectly?
I went to EcoWitt weather station, which is fully adaptable in HA. So good old Sencor was sold. A lot easier and better with the EcoWitt!
Which particular model?
Hi, I am currently trying to get Sencor data to be sent to home assistant as well and found this one article: GitHub - schizza/WeatherStation-SWS12500: Connecting Sencor SWS 12500 weather station to Homeassistant
Hope that helps at least a bit.
Hi there, there is custom component available for this station: SWS 12500 home assistant integration
