Is there somehow the possibility that you can integrate the froggit wh6000 pro in the Home Asstint?
It’s included in the RTL_433 package as the bresser_6in1 device which means you can use the RTL_433 add-on to capture 433 MHz data packets transmitted from the weather station to the base display, within Home Assistant.
