Hi, I created the template sensor
- trigger:
- platform: time_pattern
hours: /1
- service: weather.get_forecasts
type: hourly
entity_id: weather.openweathermap
response_variable: hourly
- name: Home Weather Forecast Hourly
unique_id: f257b8b3-1cee-4130-9dd6-158a1e8f13da
state: "{{ now().isoformat() }}"
attributes:
forecast: "{{ hourly['weather.openweathermap'].forecast }}"
And an automation
service: telegram_bot.send_message
message: >-
Outside temperature is {{
states.weather.openweathermap.attributes.temperature }} °C.
The raining chances are: {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[0].datetime |
as_timestamp | timestamp_custom('%H:%M') }} - {{
'forecast')[0].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[1].datetime |
'forecast')[1].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[2].datetime |
'forecast')[2].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[3].datetime |
'forecast')[3].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[4].datetime |
'forecast')[4].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[5].datetime |
'forecast')[5].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[6].datetime |
'forecast')[6].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[7].datetime |
'forecast')[7].precipitation_probability }}% {{- '\n' -}} At {{
state_attr('sensor.home_weather_forecast_hourly', 'forecast')[8].datetime |
'forecast')[8].precipitation_probability }}%
Where to input an if statement to receive only the lines if precipitation_probability is greater than zero and if all values are zero, to not receive at all?
