Weather widget clickable
Is there anyway to make the weather widget clickable?
What i’m after is the functionality of navigate on the weather widget so i can have a weather overview that then takes me to another dashboard with say a full forecast
only if you know about programming in HTML, CSS and javascript.
then you could make a custom widget for it.
or you need another widget beside it.
but there are plans to add a part to the dashboard that makes it possible to connect any kind of (pre created) actions to any widget.
but it will take some time before that is there.
Yeah I thought as much. Just thought I would ask in case someone else had already created a custom widget. I may have a look when i have a bit more time and see if i can work it out.
