The data for these sensors come from the Forecast API, it is the Current data that fails. Please try the Fix above, to see if this gets you going.
youâre fast!
fixed
everything is back
weatherbitpypi==0.24.3
did the trick for me on 2 independant instances => trested and aproved, ready for productive deployment.
Cheers, Andi
Log Details (WARNING)
Logger: homeassistant.helpers.entity
Source: helpers/entity.py:284
First occurred: 7:09:46 AM (2 occurrences)
Last logged: 12:52:53 PM
- Updating state for sensor.weatherbit_wind_direction (<class âcustom_components.weatherbit.sensor.WeatherbitSensorâ>) took 0.422 seconds. Please report it to the custom component author.
- Updating state for weather.weatherbit_maassluis (<class âcustom_components.weatherbit.weather.WeatherbitWeatherâ>) took 0.455 seconds. Please report it to the custom component author.
Iâve received this Warning couple of times last few days, any idea what could be the reason for it?
Hi Erik,
I assume that you donât get an unavailable
state for the sensors or weather entity? There is not a lot of processing going on inside the Integration itself, it mostly just pulls data from weatherbit, and presents it. So my only guess is that the connection from you to weatherbit, is lagging somehow.
Thanks for the, as usual, quick reply!
Indeed no unavailable
state for the sensors or weather entity.
Iâll keep an eye on it to see if it always happens at the same time which might be indicating something is causing it.
Thanks again.
Deal. If it continous, try adding some debug to see if this gives more info. Add this to your configuration.yaml
logger:
default: error
logs:
custom_components.unifiprotect: debug
Started getting these errors in my log today, an idea whats causing them ?
2020-07-01 16:33:55 ERROR (MainThread) [custom_components.weatherbit] Unexpected error fetching weatherbit data: 'ClientConnectorError' object has no attribute 'message'
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 962, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 949, in create_connection
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 473, in sock_connect
return await fut
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 503, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
TimeoutError: [Errno 110] Connect call failed ('54.39.183.126', 443)
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 258, in async_request
method, f"{BASE_URL}/{endpoint}"
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 1012, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 1004, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 943, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.weatherbit.io:443 ssl:None [Connect call failed ('54.39.183.126', 443)]
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 136, in async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 124, in _async_update_data
return await self.update_method()
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 47, in async_get_current_data
return await self._get_current_data()
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 73, in _get_current_data
json_data = await self.async_request("get", endpoint)
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 266, in async_request
if err.message == "Forbidden":
AttributeError: 'ClientConnectorError' object has no attribute 'message'
I got the same errors - the root cause I cannot do a lot about, as it is weatherbitâs service being unavailable. But the error handling should be better. I have just released a fix for that. It should show up soon in HACS as v0.27.
Brilliant, thanks
Donât update yet. It did not fix the errors.
/B
This is not working for me. It says none
{{ state_attr('weather.weatherbit', 'forecast')[0].condition }}
This works though, but it gives all the forecast starting with Day 1 - Day 7. Unfortunately, forecast
do not provide todayâs weather condition, but on Day 1. How do I find todayâs current condition??
{{ state_attr('weather.weatherbit_shimotoda', 'forecast')[0].condition
in ('cloudy', 'partlycloudy', 'rainy') }}
Release 0.29 is out which should now handle errors much better, when Weatherbit cannot be contacted upon startup. The Integration will now retry several times with different intervals.
You should also not see these Crash Errors in the Log file anymore.
OK, Iâll give it a try, thanks
Did you try this, seems to reflect my current conditions:
{{ state_attr('weather.weatherbit_XXXXXX', 'alt_condition') }}
There is also a cloudiness
attribute, maybe that could be used ?
Try this instead:
{{ states.weather.weatherbit_shimotoda.attributes.forecast[0].condition
Iâd avoid that as stated in the documentation:
Avoid using states.sensor.temperature.state
, instead use states('sensor.temperature')
. It is strongly advised to use the states()
, is_state()
, state_attr()
and is_state_attr()
as much as possible, to avoid errors and error message when the entity isnât ready yet (e.g., during Home Assistant startup).
Also, just noticed that my current weather condition is not then same as the first forecast day (today) so it will probably best to use the current conditions and not the forecast ?
using 29, I still see this unfortunately:
2020-07-02 12:51:41 ERROR (MainThread) [custom_components.weatherbit] Unexpected error fetching weatherbit data: Error requesting data from https://api.weatherbit.io/v2.0/forecast/daily?lat=lat6&lon=4lon3&lang=nl&units=M&key=8redacted8: None
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 504, in _request
await resp.start(conn)
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 847, in start
message, payload = await self._protocol.read() # type: ignore # noqa
File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 591, in read
await self._waiter
aiohttp.client_exceptions.ServerDisconnectedError: None
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 50, in async_get_forecast_daily
return await self._get_forecast_daily()
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 121, in _get_forecast_daily
File "/usr/local/lib/python3.7/site-packages/weatherbitpypi/client.py", line 269, in async_request
raise RequestError(f"Error requesting data from {BASE_URL}/{endpoint}: {str(err)}")
weatherbitpypi.errors.RequestError: Error requesting data from https://api.weatherbit.io/v2.0/forecast/daily?lat=lat6&lon=lon3&lang=nl&units=M&key=8redacted8: None
use the square brackets for the condition list:
in ['cloudy', 'partlycloudy', 'rainy'] }}
note I didnt check the correct working since my integration is offline now, I merely corrected the syntax
edit
actually, my post was not correct⌠both should work. pardon me please
