I messaged them and they had to manually adjust the shipping to be able to include the bird deterrent.
Would it not be easy to use some UV resistant cable ties on the top unit to create the same effect for virtually free?
Is there an indoor temp/humidity sensor in the gateway unit maybe? Like for the Ecowitt? My wind vane and rain collector is acting up and I feel I should move to something requiring less maintenance
There are no sensors in the hub.
Is it still the HACS integration that should be used? Not intregrated into core yet?
The current i integration is dependent on the cloud?
The current integration is not dependent on the cloud, except for forecast. No currently integrated into core, I know someone was working on it with an older fork, I havenāt seen any updates in awhile thou.
Thank you. That sounds great.
IMHO:
- The (non-cloud) UDP variant of the integration is not yet in HA core, although possibly close to get there: Add WeatherFlow integration by jeeftor Ā· Pull Request #75530 Ā· home-assistant/core Ā· GitHub
- the current HACS integration is dependend on cloud (at least I have not found how to configure local IP address to Tempest gateway/hub on my network): GitHub - briis/hass-weatherflow: Home Assistant Integration for WeatherFlow Stations
When will the Weatherflow Tempest integration (Pull Request #75530) be added to Home Assistant core?
I Keep Getting this messaged This stops working in version 2024.3.0. Please address before upgrading.
The integration weatherflow
is using the deprecated forecast attribute.
Please report it to the custom integration authorā¦
The developer (Me) knows. It will still work until 2024.3, so there is time to fix it.
I think Iām really really close to getting the UDP/Local integration added into core. Iām hoping once thatās done I/We can lean on one @briis to work on adding some of the cloud featuresā¦ and/or maybe Iāll just slowly start porting them overā¦ (HA has some pretty strict requirements on how integrations need to be formatted for anybody thats been painfully following my PR process)ā¦
@briis - Looks like we might make it into beta with the UDP integration. We should talk to figure out how to pull some of your cloud based features into the integration because I think that would be really great to get the forecasts inā¦
Such great timing. My Tempest weather station arrived today and is up and running. Keen to get it integrated with HA so I will start with the UDP/local integration.
@jeeftor - sorry for the dumb question but what does it mean when you are in beta for core? Should I wait for core or use HACS?
It means that in a week when the next release comes out it will have native weather flow support.
Is there an easy way to run both the Cloud custom integration and the new local integration at the same time?
Iām running the latest beta, but it appears that the custom_component is replacing the new core one
Hi @jeeftor
Yes I saw that the code is now in the beta, so congratulation on that.
How we integrate the cloud based stuff, is a good question. Because I do think that many in this community loves that the new core
integration is 100% local, and in my opinion it should stay so. That doesnāt mean there canāt be some calculated values, which I also do in the WeatherFlow2MQTT addon.
I actually already did some of the work, but in a separate custom integration with the domain name weatherflow_forecast
to avoid conflicts. This is currently in beta, and supports the new Forecast implementation required as of HA 2023.9. If anyone want to test it out, you can find instructions here on Github. I have submitted a Brand Icon, so that will show up, once it is merged.
I would really love some people who live in a different timezone than me (Central European Time), and who uses Imperial units, to do some testing. Specifically:
- is the Hourly and daily forecast times and dates correct
- are the values correct
I have also been asked to migrate the remaining sensors, that the UDP API does not provide, and I am currently evaluating that option.
No, and that is why I gave the new, Weather Entity only, Integration a new domain name. This can co-oexist with the core weatherflow integration
Oddly enough this is what I was thinking about yesterday walking the dog on whether we need a separate weather-only entity or if we could look into a hybrid local/cloud integration (something I"m considering for my IntelliFireplace integration). In my case for some strange reason the IoT Module on my fireplace seems to prioritize cloud traffic at the cost of unreliable LAN connections (which makes no sense).
I think the thing is - that some of the ācloudā sensors are different from local because I believe they take other stations into account ā¦
I sort of envisioned an options-flow where you select
USE CLOUD DATA / USE LOCAL DATA
or something ā but Iām not sure if that works in the HA context
The integration sends too much data for hourly forecasts. HA gives us a warning.
template:
# DonnƩes reƧus de Tempest WeatherFlow
# Obtenir les pƩvisions horaires
- trigger:
- platform: time_pattern
hours: /1
- service: weather.get_forecast
type: hourly
entity_id: weather.forecast_shawinigan_sud
response_variable: previsionshoraires
- name: PrƩvisions mƩtƩorologiques horaires
unique_id: previsions_meteorologiques_horaires
state: "{{ now().isoformat() }}"
icon: mdi:hours-24
attributes:
forecast: "{{ previsionshoraires.forecast }}"
@briis (Can HA support Hybrid - Local / Cloud Entities Ā· home-assistant/architecture Ā· Discussion #977 Ā· GitHub)
- It sounds like if we want to work together (in conjunction) we can work on a Hybrid Entry
- Alternatively we could go with a separate entry
Personally - the idea of a Hybrid entry kind of appeals to me although it might be more complex to write it would be a 1-stop-shop for folksā¦
(Community ā¦ thoughts?)
