Everything else works except the thing labelled “sensor.weatherman_data”. Under the Entities tab this is described as “unavailable” and no more information is given.
Check and Restart says “Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 21).”
The following is from configuration.yaml. The API key I got from the MTA has been edited and is not the same as the one in the config. Line 21 is blank, but line 22 says:
- platform: gtfs_rt
trip_update_url: “https://api-endpoint.mta.info/Dataservice/mtagtfsfeeds/nyct%2Fgtfs-l”
x_api_key: “cWNts9FmCb4ihHS9Rv9JkYHheo1eOpS2l8XXXXX”
scan_interval: 60
entity_namespace: gtfs_mta_subway
departures:- name: “Station (Northbound)”
route: “1”
stopid: “101N” - name: “Station (Southboard)”
route: “1”
stopid: “101S”
Any ideas?
