For now*, this integration creates the following sensors:
weather.<alias>, with all the weather and forecast information.
sensor.<alias>_battery, with the battery level of the device.
sensor.<alias>_firmware, with the firmware version of the device.
sensor.<alias>_rewards, with the rewards of the device (also has total_rewards as additional attribute).
sensor.<alias>_total_rewards, with the total rewards generated to date from that device.
<alias> is the alias of the device defined via the WeatherXM app. If you have not defined an alias, the device ID will be used instead.
Finally, all entities are grouped into their own device:
* I say “for now”, because I’m thinking in some more sensors and features, like the hability to manage your follows directly from the integration.
How to use it
Create your weatherXM account via the weatherXM app.
With that same app, follow any station you want to grab data from. No need to own them!
Define custom alias to your stations if you want them have custom sensor names.
On HACS, search for WeatherXM and add the integration
When configuring it, define your WeatherXM account username and password. Chose if you want to only show your devices by selecting “Filter owned devices”.
@elboletaire thanks for sharing.
For some reason, this didn’t come up when I was searching for a WeatherXM integration recently, and I’ve just found it when I was looking to add logos into the brands repo for my own integration which I’ve been working on for the past couple of weeks.
The two integrations appear to have similar functionality. It seems unnecessary to maintain both, so I’m wondering how you feel about merging the two integrations?
I’m happy to either incorporate additional features into my integration or help submit some pull requests to yours.
I’ve also just found this recently created integration as well: Weatherxm.com Integration
Although that seems much less feature complete.
Hi Benjamin, thank you for reaching out and for your interest in my integration! I’m glad to see there’s so much enthusiasm around WeatherXM and its potential in Home Assistant ^^
I’ve been working on my integration since June 2024, and it’s been well-received by the community (with over 50 downloads so far). Given that, I think it makes sense to continue developing and maintaining it. However, I completely agree that collaboration can improve the quality and features of any project.
Feel free to open any PRs you think could enhance the integration. I’m still fairly new to Home Assistant development, so there might be areas where my implementation could be refined or optimized. That said, we’ve taken somewhat different approaches in our work, so merging might require careful consideration to preserve compatibility and ensure we maintain the best of both versions.
I look forward to seeing what ideas you’d like to contribute and exploring how we can make this integration even better together!
Sounds good. Even though it’s a custom integration, I like to set my integrations up following the Home Assistant architecture by using a separate library for all external comms. So they are indeed quite a different structure.
I’ll take a more in-depth look at features on the Home Assistant side and open some pull requests for you to consider when I get a chance.
Which integration did you try?
Is there any specific missing data you’d like to see entities for as a priority?
My integration provides all weather observation data, but currently no rewards data. I think Òscar’s provides less weather observation sensors but does include some of the rewards data.
My Christmas break is over now, but when I get a chance I’m planning to submit PRs to help build up the feature set of Òscar’s integration since he published his first.
In the meantime you may be able to pick one of the two that provides the most data you are interested in.
@elboletaire could you add a “device_class: battery” to battery sensor?
This way a battery checking blueprint would monitor the station for low battery.
@elboletaire Have you any plans to develop a local integration for WeatherXM? At least to read the geo_location entity data. I’m using the data for automations and it would be great to be future proof against internet outages or subscription based API. I’m sure your integration would become more popular if there was an option for local data.
@alistairts do you have a Wifi or Helium weather station? As best as I have been able to tell there is no way to access data from a Helium weather station.
If you have a WiFi weather station there is some info in this repo for monitoring it via rtl_433:
If there’s a different API for local access I’d be happy to take a look at developing an integration with that capability.
