I haven’t made any changes or performed any updates recently but I’ve just noticed that I am no longer able to connect to my Home Assistant either via the web or app interface.
It’s still running and the automations are still working. I’ve connected via SSH and performed a reboot but that hasn’t changed anything.
I’m running the Home Assistant Operating System on a Raspberry Pi 4.
I’m afraid I don’t have much experience with HA or Raspberry Pi so don’t really know what to try.
I’ve found the home-assistant.log but it just contains these three lines.
2022-09-23 21:08:00.597 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-23 21:08:00.602 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-09-23 21:10:28.036 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Cam 1.motion_states data
Any help greatly appreciated.
Thanks.
