ZyberSE
November 12, 2016, 8:08am
1
Have anyone else noticed any problems with the web interface after 0.32.x?
I have to restart my server several times before it loads up, but the it only stays responsive for little while until it stops loading again and the server has to be restarted.
It doesn’t seam to affect automation’s though.
ZyberSE
November 14, 2016, 6:33am
3
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bedroom Evening
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Leaving Home
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Movie paused/stopped
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bedroom Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Day
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Closet Light Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Movie playing
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Evening
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Nightly Sonos Reset
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Day
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Switch Everything Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Coming Home
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Wake Me Up
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Closet Light On
16-11-13 18:07:40 homeassistant.components.zwave: Starting ZWave network.
16-11-13 18:07:42 homeassistant.components.http: Serving /api/stream to 40.0.0.78 (auth: True)
16-11-13 18:07:42 homeassistant.components.http: Serving /api/bootstrap to 40.0.0.78 (auth: True)
16-11-13 18:07:43 homeassistant.components.automation: Executing Closet Light Off
16-11-13 18:08:03 homeassistant.components.zwave: Zwave network is ready for use. All awake nodes have been queried. Sleeping nodes will be queried when they awake.
16-11-13 18:08:04 homeassistant.components.zwave: zwave ready after 24 seconds
16-11-13 18:08:04 homeassistant.components.zwave: zwave polling interval set to 60000 ms
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: homekit {'id': '00:17:88:20:49:71', 'c#': '41', 'ff': '1', 'pv': '1.0', 's#': '1', 'ci': '2', 'sf': '1', 'md': 'BSB002', 'host': 'http://40.0.0.20'}
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.15
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.45
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.30
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.48
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.11
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.58
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.86
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.47
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.25
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.37
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.16
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.13
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: home_assistant ('http://40.0.0.110:8123', '0.32.3', True)
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: mystrom ('BSB002', 'http://40.0.0.20', '00:17:88:20:49:71')
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.25:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.48:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.15:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.47:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.37:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.11:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.30:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.58:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.100:32469/DeviceDescription.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.13:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: philips_hue ('Philips hue (40.0.0.20)', 'http://40.0.0.20:80/')
16-11-13 18:08:10 homeassistant.components.discovery: Found new service: plex_mediaserver ('STORAGE', 'https://40.0.0.100:32400')
16-11-13 18:11:31 homeassistant.components.http: Serving / to 40.0.0.74 (auth: False)
16-11-13 18:26:22 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 18:29:11 homeassistant.components.automation: Executing Bathroom (upper) Day
16-11-13 18:29:34 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 18:31:11 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 18:59:27 homeassistant.components.http: Serving /states to 66.102.9.15 (auth: False)
16-11-13 19:07:46 homeassistant.components.updater: Submitted analytics to Home Assistant servers. Information submitted includes {'uuid': 'ff0924595eec4a96978f5455129cc9e3', 'virtualenv': False, 'arch': 'armv7l', 'dev': False, 'os_version': '8', 'version': '0.32.3', 'timezone': 'Europe/Stockholm', 'distribution': 'raspbian', 'docker': False, 'os_name': 'Linux', 'python_version': '3.4.2'}
16-11-13 21:10:26 homeassistant.components.http: Serving /states to 66.102.9.15 (auth: False)
16-11-13 21:27:58 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:31:49 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 21:46:01 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:48:31 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 21:52:15 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:58:02 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:00:55 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:03:34 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:03:45 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:07:19 homeassistant.components.http: Serving /api/ to 40.0.0.1 (auth: True)
16-11-13 22:07:23 homeassistant.components.http: Serving /api/config to 40.0.0.1 (auth: True)
16-11-13 22:07:23 homeassistant.components.http: Serving /api/states to 40.0.0.1 (auth: True)
16-11-13 22:07:24 homeassistant.components.http: Serving /api/ios/identify to 40.0.0.1 (auth: True)
16-11-13 22:07:24 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:08:21 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:09:31 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:12:39 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:12:59 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:13:02 homeassistant.components.http: Serving /api/services/device_tracker/see to 40.0.0.1 (auth: True)
16-11-13 22:13:03 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:22:35 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:24:33 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:29:32 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:30:00 homeassistant.components.automation: Executing Outside Night
16-11-13 22:30:00 homeassistant.components.automation: Executing Bedroom Night
16-11-13 22:30:02 homeassistant.components.http: Serving /api/services/device_tracker/see to 40.0.0.1 (auth: True)
16-11-13 22:30:04 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:32:50 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:32:53 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 22:35:33 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:47:42 homeassistant.components.http: Serving /states to 40.0.0.60 (auth: False)
16-11-13 22:52:42 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 22:54:03 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 22:56:03 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 22:59:55 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:03:30 homeassistant.components.http: Serving /states to 40.0.0.60 (auth: False)
16-11-13 23:03:45 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:09:05 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 23:09:10 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:17:48 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 23:23:34 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:25:41 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:25:51 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:27:30 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 23:29:30 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 23:41:26 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 00:00:00 homeassistant.components.zwave: ZWave heal running.
16-11-14 00:36:00 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-14 00:37:19 homeassistant.components.automation: Executing Closet Light Off
16-11-14 00:38:50 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 04:00:00 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:00 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:01 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:01 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:02 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:02 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:03 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:03 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:04 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:04 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:05 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:05 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:06 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:06 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:07 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:07 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:08 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:08 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:09 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:09 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:10 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:10 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:11 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:11 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:12 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:12 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:13 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:13 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:14 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:14 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:15 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:15 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:16 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:16 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:17 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:17 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:18 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:18 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:19 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:19 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:20 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:20 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:21 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:21 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:22 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:22 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:23 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:23 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:24 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:24 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:25 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:25 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:26 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:26 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:27 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:27 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:28 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:28 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:29 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:29 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:30 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:30 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:31 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:31 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:32 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:32 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:33 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:33 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:34 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:34 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:35 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:35 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:36 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:36 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:37 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:37 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:38 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:38 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:39 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:39 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:40 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:40 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:41 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:41 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:42 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:42 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:43 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:43 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:44 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:44 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:45 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:45 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:46 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:46 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:47 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:47 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:48 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:48 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:49 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:49 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:50 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:50 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:51 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:51 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:52 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:52 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:53 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:53 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:54 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:54 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:55 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:55 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:56 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:56 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:57 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:57 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:58 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:58 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:59 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:59 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 05:47:00 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-14 05:50:37 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-14 06:30:00 homeassistant.components.automation: Executing Wake Me Up
16-11-14 06:30:06 homeassistant.components.notify.ios: iOS push notification rate limits for iphone: 1 sent, 150 allowed, 0 errors, resets in 18:29:53
16-11-14 07:03:58 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-14 07:16:49 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 07:17:46 homeassistant.components.automation: Executing Closet Light On
16-11-14 07:18:56 homeassistant.components.automation: Executing Closet Light Off
ZyberSE
November 14, 2016, 8:22am
4
I had two warnings before that log, one was Yr.no responding and the other one was my Netatmo Outdoor module not responding for some reason. I disabled both but I still having issues with the web interface not loading at all (most of the times).
Is there any more comprehensive logs?
