Hi all
Could anyone help here? My web interface won’t load and I can’t for the life of me figure out why
I can SSH to my box, and the SMB shares all working
The custom component errors below can be ignored. They have always been there and everything works fine
Before I go and simply rebuild a new box could someone see if they could help?
2020-01-04 20:40:19 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=88 from 2020-01-04 13:57:51.097172)
2020-01-04 20:40:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component tts
File "/usr/src/homeassistant/homeassistant/setup.py", line 167, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 113, in async_setup
await tts.async_init_cache(use_cache, cache_dir, time_memory, base_url)
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 227, in async_init_cache
init_tts_cache_dir, cache_dir
concurrent.futures._base.CancelledError
2020-01-04 20:40:20 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Google Cast for cast
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 190, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/cast/__init__.py", line 26, in async_setup_entry
await home_assistant_cast.async_setup_ha_cast(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/cast/home_assistant_cast.py", line 26, in async_setup_ha_cast
user = await hass.auth.async_get_user(user_id)
File "/usr/src/homeassistant/homeassistant/auth/__init__.py", line 135, in async_get_user
return await self._store.async_get_user(user_id)
File "/usr/src/homeassistant/homeassistant/auth/auth_store.py", line 72, in async_get_user
await self._async_load()
File "/usr/src/homeassistant/homeassistant/auth/auth_store.py", line 289, in _async_load
await self._async_load_task()
File "/usr/src/homeassistant/homeassistant/auth/auth_store.py", line 296, in _async_load_task
self._store.async_load(),
2020-01-04 20:40:20 ERROR (MainThread) [homeassistant.components.unifi] Unknown error connecting with UniFi controller:
2020-01-04 20:40:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component device_tracker
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 150, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 95, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 376, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/helpers/discovery.py", line 151, in async_load_platform
setup_success = await setup.async_setup_component(hass, component, hass_config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 45, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 136, in _async_setup_component
hass, config, integration
File "/usr/src/homeassistant/homeassistant/config.py", line 772, in async_process_component_config
p_integration = await async_get_integration_with_requirements(hass, p_name)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 44, in async_get_integration_with_requirements
await async_process_requirements(hass, integration.domain, integration.requirements)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 65, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 45, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3137, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
File "/usr/src/homeassistant/homeassistant/components/device_tracker/__init__.py", line 183, in async_setup
await tracker.async_setup_tracked_device()
File "/usr/src/homeassistant/homeassistant/components/device_tracker/legacy.py", line 324, in async_setup_tracked_device
await asyncio.wait(tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
await waiter
2020-01-04 20:40:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component light
item = parse(item)
