Is it possible to use both Web Server and ESP32 Web Server?
Try it out and tell us!
ah !
Maybe I should have included more detail… sorry!
I think this is an issue when installing the ESP32 Web Server via OTA.
For the first install its ok, then fails each time after as below…
[14:59:56][C][mdns:085]: Hostname: bird_cam
[14:59:56][C][esp32_camera_web_server:088]: ESP32 Camera Web Server:
[14:59:56][C][esp32_camera_web_server:089]: Port: 8080
[14:59:56][C][esp32_camera_web_server:091]: Mode: stream
[14:59:56][E][esp32_camera_web_server:096]: Setup Failed
[14:59:56][C][esp32_camera_web_server:089]: Port: 8081
[14:59:56][C][esp32_camera_web_server:093]: Mode: snapshot
I decided to follow the below method which worked.
- Created YAML in ESPHome to include both web servers
- Downloaded file as a .bin file
- Re-Flashed ESPHome using the Web Tools
- Connected to ESP Web Tools WiFi
- Uploaded the .bin file via OTA
- SUCCESS - I can now accsss via both ports
api:
web_server:
port: 443
- port: 8080
mode: stream
- port: 8081
mode: snapshot
Went to update my cam today, and got the same error as above!
- I’ll check my above workaround see if that will work
- I also need to update ESP Home as I’m currently using v2021.12.3 - so not sure if that’ll make a difference.
