Web server of the ESP not showing the values from sensors
I have similar problkem on nodemcu v3 ESP8266 board before, so I have bought new one - wemos d1 mini pro and another one ina3221 sensor,
So I have made similar code:
esphome:
  platform: ESP8266
  board: d1_mini_pro
wifi:
  ssid: "aaa"
  password: "aaaa"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
         port: 80
i2c:
   - id: bus_a
     sda: 4
     scl: 5
     scan: True
# Example configuration entry
   - platform: ina3221
     address: 0x40
     channel_1:
      shunt_resistance: 1
      current:
        name: "INA3221 Channel 1 Current"
      power:
        name: "INA3221 Channel 1 Power"
      bus_voltage:
        name: "INA3221 Channel 1 Bus Voltage"
      shunt_voltage:
        name: "INA3221 Channel 1 Shunt Voltage"
     channel_2:
      shunt_resistance: 1
      current:
     channel_2:
      shunt_resistance: 1
      current:
        name: "INA3221 Channel 2 Current"
      power:
        name: "INA3221 Channel 2 Power"
      bus_voltage:
        name: "INA3221 Channel 2 Bus Voltage"
      shunt_voltage:
        name: "INA3221 Channel 2 Shunt Voltage"
     channel_3:
      shunt_resistance: 0.9
      current:
        name: "INA3221 Channel 3 Current"
      power:
        name: "INA3221 Channel 3 Power"
      bus_voltage:
        name: "INA3221 Channel 3 Bus Voltage"
      shunt_voltage:
        name: "INA3221 Channel 3 Shunt Voltage"
     update_interval: 10s
again on the new board - on the web server on the esp I see the table with labels as below, but the columns for the values are clear - there is no any digits/letters there.
On the CLI output when uploading the code through the USB I see all results with refreshing ones as they appear on the sensor.
what should I do more ?
regards
please format your code.
editor bypassed [code] inline marks :expressionless:
I have the same issue with some of my sensors. Mainly the text sensors.
so, what to do now?
The web values will be blank until a sensor has a value. However if the values are changing in the log out put they should be reflected in the web page. Tried refresh? Or clearing cache.
In any event the web page doesn’t always work. It uses a lot of precious ram and isn’t really core esphome. The true test is if you are getting the values into home assistant.
