So after one of the updates I can’t access Home Assistant via web (local or external url)
Samba share still works and my automation also do work.
What can I do to restore it?
Do you have SSH set up?
Yes, I have direct access to rpi with hooked monitor and keyboard.
Check your logs for errors.
That broke it https://hacs.xyz
In any case I took an opportunity and moved the whole thing from raspberry pi to synology docker.
So much speed now!
