Hi thank you for answering so fast. Also i’m more an hardware than a software guy, I put the complete log, so if you see something…
Always happy to learn
Log Details (ERROR)
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/weback_robot_vacuum/WebackVacuumApi.py:64
Integration: weback_robot_vacuum
First occurred: 11:57:16 AM (1 occurrences)
Last logged: 11:57:16 AM
Error during setup of component weback_robot_vacuum
File "/usr/local/lib/python3.9/site-packages/anyio/_core/_sockets.py", line 218, in connect_tcp
await event.wait()
File "/usr/local/lib/python3.9/site-packages/anyio/_backends/_asyncio.py", line 1842, in wait
if await self._event.wait():
File "/usr/local/lib/python3.9/asyncio/locks.py", line 226, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.9/site-packages/httpcore/backends/asyncio.py", line 109, in connect_tcp
stream: anyio.abc.ByteStream = await anyio.connect_tcp(
await event.wait()
File "/usr/local/lib/python3.9/site-packages/anyio/_backends/_asyncio.py", line 658, in __aexit__
raise CancelledError
File "/usr/local/lib/python3.9/site-packages/httpcore/_exceptions.py", line 8, in map_exceptions
yield
File "/usr/local/lib/python3.9/site-packages/anyio/_core/_tasks.py", line 118, in __exit__
raise TimeoutError
TimeoutError
File "/usr/local/lib/python3.9/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/usr/local/lib/python3.9/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.9/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.9/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.9/site-packages/httpcore/_async/connection.py", line 86, in handle_async_request
raise exc
File "/usr/local/lib/python3.9/site-packages/httpcore/_async/connection.py", line 63, in handle_async_request
stream = await self._connect(request)
File "/usr/local/lib/python3.9/site-packages/httpcore/_async/connection.py", line 111, in _connect
stream = await self._network_backend.connect_tcp(**kwargs)
File "/usr/local/lib/python3.9/site-packages/httpcore/backends/auto.py", line 29, in connect_tcp
return await self._backend.connect_tcp(
File "/usr/local/lib/python3.9/contextlib.py", line 137, in __exit__
self.gen.throw(typ, value, traceback)
File "/usr/local/lib/python3.9/site-packages/httpcore/_exceptions.py", line 12, in map_exceptions
raise to_exc(exc)
httpcore.ConnectTimeout
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/config/custom_components/weback_robot_vacuum/__init__.py", line 50, in async_setup
await weback_api.login()
File "/config/custom_components/weback_robot_vacuum/WebackVacuumApi.py", line 64, in login
r = await client.post(AUTH_URL, json=data)
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1842, in post
return await self.request(
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1527, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1614, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1642, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1679, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.9/site-packages/httpx/_client.py", line 1716, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.9/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ConnectTimeout
