Hello, help me please
I would like to try this integration, but actually I did not manage to login.
Iāve tried to login directly using the python library weback-unofficial without luck.
I can successfully relogin in the Android WeBack App using my email adress and password, the region is āGermanyā.
I am now trying to login directly with the following curl command:
curl -H 'Content-Type: application/json' -d '{"App_Version": "android_3.9.3", "User_Account": "[email protected]", "Password": "..."}' https://www.weback-login.com/WeBack/WeBack_Login_Ats_V3
I tried with plain text password as well as hashed using python md5(password.encode('utf-8')).hexdigest()
The response is always:
{"Request_Result": "fail", "Fail_Reason": "account or password is incorrect"}
Any suggestions?
ok, sorry for the above post. Now using component from agustin-e which seems to be working fine so far
Hi have a ikohs netbot s15 and does not work
Hi!
We need some more information about whatās wrong if you want help ?
Error message ? Some log ?
Thanks for great work. I am rocking with mamibot EXVAC-880
So far it works fine. Had some issues on startup but that was because at the first init/ha-restart weback cloud was rejecting all logins. Next morning all was resolved and after ha restart, my 880 appeared to entities list. Will test out current features, most seem to work so far. Will update progress at some point.
Again, nice work, @agustin-e
Kenno
EDIT: Opened an issue in github for my findings
Hi !
I decide to completly rewrite a component for Weback and Tesvor robot.
Sorry for your repo @agustin-e but i canāt made a PR to your code i did a deeply rewrite.
I improve a lot of stuff like :
- Improve error handling
- Implement a real HA async update process
- Add full mop support
- Add attributes like āClean time, Clean areaā¦ā
- Modulate refresh time : 5sec when robot is working, 120sec when itās idle and charged
- Improve HTTP api connexion with retry process, and cached credentials to avoid excess call to API.
- Add full connexion parameters (eg : for user from Tesvor or other robot platform)
https://github.com/Jezza34000/homeassistant_weback_component
For the moment only checked with my Neatsvor X600, but i took manly my code from my Weback plugin for Jeedom who was tested with many brand, and many models.
Interesting upgrade!
Could you share a screenshot of your final card please? Also, are the attributes saved as single entities so that you can call their states in automations?
Great work, @Jezza34000! Thank you for your efforts!
Unfortunately I cannot make it run, it says unable to login. Iāve got a Tesvor S6 Turbo and configured it with the Tesvor App. Your readme does not give any hint what I need to set in āapplicationā configuration field, also did not find options in code.
Would be very happy to get it working and test it.
Hi @dramsauer
When you said you are unable to login itās with ārequiredā only like : username, password, region ?
About other parameter i didnāt give more information cause i donāt have it. Yugong Machinery (manufacturer) donāt give any documentation about their API.
I know itās required from other platform (like Tesvor, in your case) API request have thoses field when login, but i donāt know what really expected.
You can try with adding this :
application: Tesvor
(itās case sensible, take care about first upper)
If not working we will try other solutionā¦
Edit : I just update readme.md and i improve login function to have more details about whatās wrong. Update your component before test
Works with my vacuum as well Weback integration: mamibot EXVAC-880
@Jezza34000 Thanks, for effort of making the rewrite and yes, it was at some point 502
Keeping an eye on the integration for a few days and then will give feedback. Login and ping worked, robot located oneself when I pinged the location from HA
EDIT: first quick finding:
Hi.
Thanks for your work.
I actually get some issues with the integration. I can see the vacuum card but it says that the entity is no longer provided by the integration weback_vacuum.
So my robotts name is āNonoā
Its an Tesvor X500 and i use it normaly via the Weback app.
when i look at the log files i see 3 Errors.
Logger: homeassistant.components.vacuum
Source: custom_components/homeassistant_weback_component/vacuum.py:211
Integration: Vacuum (documentation, issues)
First occurred: 13:41:31 (2 occurrences)
Last logged: 13:41:31
Error adding entities for domain vacuum with platform weback_vacuum
Error while setting up weback_vacuum platform for vacuum
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 428, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 691, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 777, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 533, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 574, in _async_write_ha_state
attr.update(self.extra_state_attributes or {})
File "/config/custom_components/homeassistant_weback_component/vacuum.py", line 211, in extra_state_attributes
"clean_area": round(self.device.robot_status['clean_area'], 1),
KeyError: 'clean_area'
Dieser Fehler wurde von einer benutzerdefinierten Integration verursacht
Integration: homeassistant_weback_component
First occurred: 13:42:15 (1 occurrences)
Last logged: 13:42:15
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 893, in _async_registry_updated
Logger: homeassistant.helpers.integration_platform
Source: loader.py:739
First occurred: 13:41:30 (7 occurrences)
Last logged: 13:43:09
Unexpected error importing weback_vacuum/system_health.py
Unexpected error importing weback_vacuum/media_source.py
Unexpected error importing weback_vacuum/logbook.py
Unexpected error importing weback_vacuum/cast.py
Unexpected error importing weback_vacuum/hardware.py
File "/usr/src/homeassistant/homeassistant/helpers/integration_platform.py", line 40, in _async_process_single_integration_platform_component
platform = integration.get_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 722, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 739, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1004, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'custom_components.homeassistant_weback_component.diagnostics'
What have i done:
- Copied the integration into custom_components via WinSCP
- Added lines to my configuration.yaml
weback_vacuum:
username: [email protected]
password: MyFancyPassword
region: 49
I hope you can do something with the information.
Update:
I just debugged the lib and found some things
It seems that Tesvor has some other extra attributes:
"connected": "true",
"upgrade_logic": "1.0",
"robot_x": None,
"robot_y": None,
"point_num": None,
"clean_time": None,
"config_app": "WeBack",
"firmware_version": "6.0.8.0422s",
"yugong_software_version": "6.0.8",
"device_2_app_proto_version": "1.1",
"device_2_app_proto_info": {
"mapdata_src": "s3",
"mapdata_info": "es_yw_2.0",
"direction_ctl": "user_topic"
"working_status": "PileCharging",
"final_edge": "on",
"optical_flow": "on",
"fan_status": "Pause",
"water_level": "None",
"left_water": -1,
"voice_switch": "on",
"uv_lamp": "unsupport",
"cliff_detect": "enable",
"error_info": "NoError",
"battery_level": 37,
"vendor_firmware_version": "6528",
"chassis_hardware_version": "00",
"offset_hours": 2,
"offset_minutes": 0,
"Voicebox_Source": "null"
Also be aware that āclean_timeā can have None as value. So there will be an error with the divide function. i replaced it in my vacuum.py line 212 with
"clean_time": 0 if self.device.robot_status['clean_time'] == None else round(self.device.robot_status['clean_time'] / 60, 0),
I commented all keys that are not in my robot_status.
Here is my vacuum.py line 209 to line 215
"robot_mode": mode,
"error_info": self.device.error_info,
# "clean_area": round(self.device.robot_status['clean_area'], 1),
# "volume": self.device.robot_status['volume'],
"voice": self.device.robot_status['voice_switch'],
# "undisturb_mode": self.device.robot_status['undisturb_mode'],
So now iām able to control my Tesvor X500, but i just testet start and stop.
I will test more in the future.
- time.sleep is now fix in last version.
- āNoneā bug fix is pushed to lastest version
Thank you for your help guys !
@Hiswif i love you robotās name
Hi @Jezza34000 thank you very much for your work.
In the last version I have problems with integration.
First occurred: 11:50:59 (6 occurrences)
Last logged: 11:50:59
Unexpected error importing weback_vacuum/recorder.py
ModuleNotFoundError: No module named 'custom_components.weback-home-assistant-component.diagnostics'
Source: custom_components/weback-home-assistant-component/vacuum.py:213
Integration: Odkurzacz (documentation, issues)
First occurred: 11:50:59 (2 occurrences)
File "/config/custom_components/weback-home-assistant-component/vacuum.py", line 213, in extra_state_attributes
KeyError: 'volume'
OK looks like you robot donāt have soundā¦ ? Which model is it ?
I push an update to avoid this problem
My robot is neatsvor x500, I have sounds turned on in the weback application.
@Jezza34000 I checked the new patch you posted. The robot started working properly - Thank you!
However, there is one more error in the logs
First occurred: 12:50:25 (7 occurrences)
Last logged: 12:52:01
About this :
I need to investigateā¦ I donāt have this error and i donāt really know what the problemā¦
