hi
from my synology system (surveillance) i want to call a script based on a action, see screenshot below
but for some reason, when i click on test button if fails, i think i am missing some stuff maybe, but i dont know what
hi
I believe you have to authenticate with Authorization: Bearer TOKEN_KEY
As far as I know you cannot use the API with your normal login credentials.
I know it’s been a while since you posted this and you’ve probably found the solution already, however, as I’ve been working on this today I thought the solution might help someone else.
The action needs to be set up like this:
Then, in your automation:
- alias: 'Carpark Camera Alert'
initial_state: 'on'
- platform: webhook
webhook_id: carpark_camera
condition:
condition: and
conditions:
etc.
thx, yes, with http it works indeed, i use https on my local lan, then it doenst work
but i have a workaround anyway now
to use nabucasa url
or
i have now a small webserver enabled on my synology, i have a php file there that i call from the actions, in that .php file , i can call my https with POST, in php you can define to ignore invalid certificates…
