Webhook errors
I keep getting two unregistered webhook errors in my system log. What’s the best way to fix it so I don’t have them any longer?
Take a peek at the following thread: How to help us help you - or How to ask a good question
Can we see the relevant portion of your system log? I’d be happy to help you try and fix this but I need to be able to see the actual errors first.
Have you just installed or are using the android app Ariela
If so have a look in its support thread
Here’s what’s in my system log:
019-06-12 19:47:27 INFO (SyncWorker_6) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:47:27 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140680485335112] Error handling message: Unauthorized
File “/usr/src/homeassistant/homeassistant/components/websocket_api/connection.py”, line 83, in async_handle
handler(self.hass, self, schema(msg))
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 52, in handle_subscribe_events
raise Unauthorized
homeassistant.exceptions.Unauthorized: Unauthorized
2019-06-12 19:47:27 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 5a3a82376867cfd84b360eb081467169b79e56a282e215f1d97b710ee2ac58f9
2019-06-12 19:47:40 INFO (SyncWorker_4) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:47:53 INFO (SyncWorker_13) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:48:02 INFO (SyncWorker_11) [custom_components.google_geocode.sensor] google request sent
2019-06-12 19:48:02 INFO (SyncWorker_5) [custom_components.google_geocode.sensor] google request sent
2019-06-12 19:48:06 INFO (SyncWorker_19) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:48:19 INFO (SyncWorker_18) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:48:32 INFO (SyncWorker_12) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:48:45 INFO (SyncWorker_16) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:48:58 INFO (SyncWorker_16) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:49:03 INFO (SyncWorker_6) [custom_components.google_geocode.sensor] google request sent
2019-06-12 19:49:11 INFO (SyncWorker_15) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:49:24 INFO (SyncWorker_19) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:49:36 INFO (SyncWorker_7) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:49:49 INFO (SyncWorker_0) [homeassistant.components.ddwrt.device_tracker] Checking ARP
2019-06-12 19:49:52 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 7ae8b1b4c5462b6e631f6eeb3fe5db2986f4a361b8e14c1a70f89c4b504d6672
I’m using Ariela Pro. I’ll check in that area to see if Ariela may be the problem.
