Hi All
I have for a very long time used Home assistant and was using the:
OLD ONE:
http:
server_port: 8123
base_url: http://192.168.0.12:8123
I have a working https cert. from my reverse proxy (Synology)
So I have a working cert. https://mydomain.com
I then update my configuration YAML to:
NEW ONE:
elevation: 24
time_zone: Europe/Copenhagen
external_url: "https://mydomain.com"
internal_url: "http://192.168.0.12:8123"
# Enables configuration UI
config:
http:
server_port: 8123
use_x_forwarded_for: true
trusted_proxies:
- 192.168.0.6
- 192.168.0.9
- 192.168.0.10
- 192.168.0.0/24
ip_ban_enabled: true
login_attempts_threshold: 5
But when I try to access the “Smartthing” plugin I get a:
The instruction says:
But I can’t find what I am missing?
The HA is working fine with the cert. and my new domain using the reverse proxy?
And I did add this proxy to the conf. YAML?
Home someone can help me Tokens and the new security have eluded me for some time now
(I am running the latest and greatest HA version HassOS 4.10)
Update for some reason the external access is not recognized by HA?
