Webhook in automation
Hello, I currently have an IPX800 v3 that I’d like to control using web requests. The goal is to create a virtual button on ha and an automation to send a web request.
But I can’t do it, can someone help me?
Yes, but more information is needed. The Restful command is the most likely candidate, but without details on what is expected on the receiving end this is as much as we can do for you now.
Depending on what’s connected to the IPX800 v3 Web Relay board (I had to Google what is was) you might also want to consider defining some kind of template device instead of just a command button. That way the UI can present it for what it actually controls.
