RAW29
October 11, 2024, 12:16pm
1
I’m trying to work out how to store all the information receivesd in JSON via a Webhook to a Sensor so that I can use that data for instance on dashboards, or to update the Device_Tracker and have the data stored during a reboot of HA.
This is the JSON received:
[{'BatteryLevel': 100, 'BatteryVoltage': 4.011, 'ChannelId': 1225350, 'CodecId': 142, 'DeviceId': 5998436, 'DeviceName': 'Robs Car', 'DeviceTypeId': 2334, 'EngineIgnitionStatus': False, 'EventEnum': 240, 'EventPriorityEnum': 1, 'ExternalPowersourceVoltage': 0, 'GsmMcc': 234, 'GsmMnc': 15, 'GsmOperatorCode': '23415', 'GsmSignalLevel': 60, 'Ident': '8646360657336459', 'MovementStatus': False, 'Peer': '85.255.237.214:63364', 'PositionAltitude': 49, 'PositionDirection': 357, 'PositionLatitude': 51.123456, 'PositionLongitude': -1.123456, 'PositionSatellites': 12, 'PositionSpeed': 0, 'ProtocolId': 14, 'ServerTimestamp': 1728647840.668736, 'Timestamp': 1728647838}]
As this data is received I would like to write all the different values into a Sensor. Is there a way to parse the data and create attributes in the sensor for each value, so even if the JSON changed (add or subtract values) all the values would be stored?
I’m new go all of these and learning as I go, so if you can provide any instructions as gto where to create anything you suggest that would be really helpful.
Thanks for the help.
NathanCu
(Nathan Curtis)
October 11, 2024, 12:24pm
2
Look up the second entry under templating.
A collection of posts on how to perform common tasks and deal with common problems. This Guide is intended for those new to Home Assistant, those that are struggling for answers on some subjects, and those in troubleshooting mode. All of the Home Assistant Posts are made by Community Members and most are posted in Community guides so if you would like to correct something, that is possible.
Getting Started With The Forum
Discourse New User Guide (this forum uses the Discourse software)
H…
Its not for the faint of heart but it works.
That said *saving the data off somewhere isn’t usually the best course of action for HA. HA works best with events - not polling
Let us know what your source data is and how you get it and someone will definitely point te way.
Troon
(Troon)
October 11, 2024, 12:41pm
3
This seems to be exactly what you need:
RAW29
October 11, 2024, 5:03pm
4
Hi
The source data is coming from a vehicle tracker. It’s routed via a 3rd party who converts the raw stream from the tracker to JSON and then POSTs the JSON to a webhook I created on HA.
From there I extract the longitude and latitude data and update a device_tracker which is displayed on a map on a dashboard.
That part works flawlessly, but along with the positioning data there is a whole host of other info I would like to store in a sensor so I can display it alongside the map and also create automations, for instance if the vehicle leaves a geofenced area there will be an instant alert and I’d like to then alert via HA to various locations.
This is the data received.
"BatteryLevel":95,
"BatteryVoltage":3.905,
"ChannelId":1225350,
"CodecId":142,
"DeviceId":5998436,
"DeviceName":"Robs Car",
"DeviceTypeId":2334,
"EngineIgnitionStatus":false,
"EventPriorityEnum":0,
"ExternalPowersourceVoltage":0,
"GsmMcc":234,
"GsmMnc":15,
"GsmOperatorCode":"23415",
"GsmSignalLevel":60,
"Ident":"864636065799777",
"MovementStatus":false,
"Peer":"85.255.237.123:23273",
"PositionAltitude":49,
"PositionDirection":357,
"PositionLatitude":51.99997,
"PositionLongitude":-1.82427,
"PositionSatellites":14,
"PositionSpeed":0,
"ProtocolId":14,
"ServerTimestamp":1728651530.192758,
"Timestamp":1728651438
Troon
(Troon)
October 11, 2024, 5:14pm
5
RAW29:
If those square brackets are correct, you’ll need to use, for example:
trigger.json[0]['BatteryLevel']
If your device tracker is working, use Zones.
RAW29
October 11, 2024, 8:48pm
6
Thanks for the help so far. Been looking over the links and suggestions and watched a few videos, but still stuck on this.
I have created a templates.yaml file and linked that in the configuration.yaml, and have tried to add the template witht he webhook trigger in there.
I don’t seem to be able to get this to work.
Here is what i have in the templates.yaml
#### Store Car Tracker Attibutes ####################
- trigger: webhook
Webhook_id: -2spsF8QBr-xxx_xxxxxxxxxx
- name: "Car Tracker Sensor"
state: "{{as_datetime(trigger.json[0]['Timestamp'])}}"
json_attributes_path: "$.0"
json_attributes:
- "BatteryLevel"
- "BatteryVoltage"
- "EngineIgnitionStatus"
- "ExternalPowersourceVoltage"
- "MovementStatus"
- "PositionAltitude"
- "PositionDirection"
- "PositionLatitude"
- "PositionLongitude"
And this is the link in the configuration.yaml
#### Yaml File Locations ############################################
script: !include scripts.yaml
scene: !include scenes.yaml
homeassistant:
customize: !include customize.yaml
template: !include templates.yaml
Does this look correct as I’m trying to coble together bits of information from various places as I can’t find an example of what I am trying to do.
Troon
(Troon)
October 11, 2024, 8:51pm
7
Look again at the example in the link I posted. You’re missing another trigger
, and webhook_id
needs to be lower case.
RAW29
October 11, 2024, 9:06pm
8
does this look better?
- trigger:
- trigger: webhook
webhook_id: -2spsF8QBr-KxL_yGKryIkJIj
- unique_id: a1ed2d7d-bd35-4c3c-8e6f-9c1416b6af3c
json_attributes:
- "BatteryLevel"
- "BatteryVoltage"
- "MovementStatus"
Troon
(Troon)
October 11, 2024, 9:09pm
9
RAW29:
Does it work? Might need to put that webhook ID in quotes
webhook_id: "-2spsF8QBr-KxL_yGKryIkJIj"
RAW29
October 11, 2024, 9:18pm
10
Hopefully I’m looking in the right place, Setting > Devices & Services > Entities and searching for “sensor.car_tracker_sensor”.
If thats the right place I’m not seeing the sensor being created.
I can see this in the logs:
2024-10-11 22:13:58.639 ERROR (MainThread) [homeassistant.config] Invalid config for 'template' at templates.yaml, line 10: 'json_attributes' is an invalid option for 'template', check: sensor->0->json_attributes
Invalid config for 'template' at templates.yaml, line 9: 'json_attributes_path' is an invalid option for 'template', check: sensor->0->json_attributes_path
RAW29
October 11, 2024, 9:24pm
11
So, I just deleted some of the code so it was as follows:
- trigger:
- trigger: webhook
state: "Event Fired"
and this now works and i can see the sensor
Just need to work out how to add the JSON values as attributes.
Troon
(Troon)
12
Ah yes, no json_attributes
in a template sensor, missed that. You’ll need to call out the attributes individually:
attributes:
battery_level: "{{ trigger.json['0']['BatteryLevel'] }}"
Docs for attributes: Template - Home Assistant
Or as separate sensors like in the linked example.
RAW29
October 11, 2024, 9:40pm
13
Thanks for the guidenace, all working now.
