My alarm system can sends an “Action URL- http/https” with which I want to trigger an automation in HA.
The problem is, when I enter the link in the alarm system (Lupus XT2 +) and start a test run, I don’t get an error, but the WebHook trigger is not addressed either.
If I run the webhook via curl from another server in the LAN everything works.
How can I test if the alarm sends the correct command (post) and no get?
Tested so far:
HA tested internally - automation works
HA terminal - curl - works
Other Linux server in Lan - curl (curl -X POST -H “Content-Type: application/json” http://your-home-assistant:8123/api/webhook/some_hook_id) - works
I copied a sample hook and overlooked that it was https:/…
Correct is of course http://… I
Thanks for the info, I have subsequently improved this in the first post.
About the Lupus configuration:
I have both cameras and relays (Shelly) that I can address via the alarm systems internal Action URL’s.
I have taken a Shelly (2 relays) and currently use that as a trigger for the ALarm automation:
Lupus - Arm Home = Relay 1 on via Action URL
Lupus - Arm Full = Relay 2 on per Action URL
Lupus - DIsarm = Relay 1&2 off per Action URL
This works fine. Using the webhook I was hoping to save the relay and run the automation directly.
Unfortunately this does not work so far between Lupus and HA.
