Hello
I am new to HA, I am finishing the migration of an eedomus controller to HA installed on a mini PC with HAOS, more than 60 peripherals (zwave, zigbee and wifi), with good results.
I am trying to integrate a sensor that collects wind speed supplied by an anemometer controlled by a raspberry pi zero.
It currently sends the speed to the eedomus controller every 30 seconds. Now I’m trying to send it to HA and receive it on a sensor
what I sent from the raspberry is
payload = {'value' : windspeed }
conn =requests.post(HA_URL, params=payload)
where HA_URL is: local ip of home assistant:8123/api/webhook/rpv
the sensor in the template.yaml file is:
- platform: webhook
webhook_id: rpv
local_only: true
allowed_methods:
-GET
-POST
sensor: - name: “RPV - Wind speed”
state: “{{ trigger.data.windspeed}}”
unit_of_measurement: “Km/h”
The error I receive in the logs is:
Logger: homeassistant.helpers.sensor
Source: helpers/trigger_template_entity.py:208
First occurred: 17:26:26 (2 occurrences)
Last logged: 17:27:26
Error rendering state template for sensor.rpv_velocity_viento: UndefinedError: ‘multidict._multidict.MultiDictProxy object’ has no attribute ‘windspeed’
thanks for your help
Greetings
