I was using the Webhooks relay node and worked quite well at the start. Then out of nowhere it stopped sending stuff through to Node-Red.
On looking at the node it sems to have lost its token. I reinput the token and it works again but stops. Open it up again and no token. Anyone else have a simalar issue. When it works it is really good but it simply seems to loose it ways
Its been a while Matt. I ended up using MQTT to get around the issue at the time and then didnt look for again at the original issue. I used to have the movement call the webhook so ended up using the same thing to run a MQTT publish on a linux server and pull it into HA via the subscribe
