iorifly
(Renato Barbosa)
1
Dear,
I am trying to start a trigger through a webhooks. My setup is as follows.
Automation:
alias: Uber chegando
description: Quando o Uber estiver chegando
- platform: webhook
webhook_id: uber_chegando
condition: []
- data:
data_template:
message: Renato, o seu Uber,está chgeando.
service: tts.watson_tts_say
- data:
type: announce
service: notify.alexa_media_alexa_cozinha
- data:
type: announce
service: notify.alexa_media_alexa_escritorio
In my ifttt I have the following URL
https://hooks.nabu.casa/url****** **** * * * * * * * * *=/api/webhook/uber_chegando
Nothing happens when I call the url. I have error 404.
404: Not Found
As you can see, I’m having trouble setting the webhooks trigger. What am I doing wrong ? I am using the POST method …
iorifly
(Renato Barbosa)
3
Missing enables the webhooks option. Sorted out.
iorifly
(Renato Barbosa)
4
I am having this error. Can you help me?
NOTE: My body field in ifttt applets is in arm. I saw that you don’t have to.
Error processing webhook uber_juliana_chegou_em_casa
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 77, in async_handle_webhook
response = await webhook["handler"](hass, webhook_id, request)
File "/usr/src/homeassistant/homeassistant/components/automation/webhook.py", line 31, in _handle_webhook
result["json"] = await request.json()
File "/usr/src/homeassistant/homeassistant/util/aiohttp.py", line 41, in json
return json.loads(self._text)
File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
iorifly
(Renato Barbosa)
5
I will try to add in the applet body the ** {} **
The problem I can test only when calling an uber …
