I dont understand the errormessage but I am afraid I need perl.
Official Documentation does also not mention this.
As you can see, both instances are not on the same machine.
They are on the same network and other services i host are working flawlessly.
So its not a network issue or something else.
I installed the latest 2024.5.1 and hoped it might fix it (you never know) but it stayed the same so it didnt seem to be an issue with HA in general.
Looks like something was def. missing on my Ubuntu-machine.
Following did the trick:
In oder to install the XML::parser i needed to install a c compiler first:
