i try to use webos.select_sound_output
service to select bt_soundbar
. It looks like the mode is switched but BT device doesn’t connect.
Mayby somebody know is it possible to do that?
Jacek.
Jacek.
Any luck here, Jacek? Hacking my way through this topic also, but sadly with little success.
Some of the webOS commands only work for newer models, but it is not well documented which commands work for which version.
I have C9 series from 2020 you think it should work? Where i can find any kind of docs to delve into the topic?
As I said, it’s no where really documented. We kind of simply observed this. have a c8 with webOS 5, c9 already has os6 as far as I know, so at least you have more functionality than I have
