Hello @ all !
Until couple of days before, I was still running HA OS from mid 2023, which I did not upgrade.
In my configuration.yaml, I had definded a switch to open my garage door, which triggers an ip-relay… The code was as follows:
tch:
- platform: command_line
scan_interval: 5
switches:
garagentor:
friendly_name: "Garagentor"
command_on: "curl -k --http0.9 http://192.168.178.9/state.xml?relay2State=2&pulseTime1=5"
command_off: "curl -k --http0.9 http://192.168.178.9/state.xml?relay2State=2&pulseTime1=5"
This was working fine until I made an update to the actual version. After that, the entry is still in configuration.yaml, but the switch in frontend has disappeared, saying that the entity is no longer available…
Can anybody help ? - This would be highly appreciated !
Cheers
Marco
