Webrtc card
Does anyone have this issue with webrtc card? It did update when I go to the card but no I have to toggle the stream then refresh the page.
Eufy integration
Webrtc
Hi, yes, for me it’s the same. I’m pressing on the Play to turn on streaming - picture remains still. I navigate away from the page, then go back, then the stream loads OK. If I press the play, then press it again, it tells me that “device_livestream_already_running”. So it interacts with go2rtc and the eufy pretty well, only the streaming has hiccups.
Did you find any solution to this?
Hi everyone,
I have the same behaviour.
Did you get this solved, it`s quite a long time ago. :wink:
Thank you.
