Ensure your stream is H264 encoded not H265 (some browsers especially on mobile devices do not support).
I have a similar issue with my cameras (via Hikvision NVR using rstp). They have a high quality and lower quality stream. I wanted to use the lower quality so running over 4G on my phone would perform better. However, lower quality stream does exactly as you describe however, high quality stream works. I have not yet worked out exactly why.
No ideas? That would suck i bought this tablet only for this goal. Didn’t expect a stream that works on windows and android phones to not work on a recent Samsung tablet.
Edit 1: I just remembered that I have an old Pixel 3 XL phone and decided to fire it up to see how webrtc runs on it, and guess what? It works flawlessly. Even normal HLS (not HLSLL) works just fine! Camera feed loads up instantly with no lag or delay! I’m not sure now what is preventing webrtc from running properly on android tablets. Is it really a hardware limitation or there’s a software situation that I’m not aware of.
Just chiming in on my part. Experiencing the exact issue you’re having on my Samsung tablet, that I also specifically bought for this purpose. I actually have two older android tablets that I thought were having issues streaming because they were older models, thus me getting this newer Samsung A8 tablet. But of course, the issue isn’t really that.
I currently don’t have a solution figured out yet. From what I can see this is definitely an Android streaming issue and not webrtc or HLSLL issue. Those streams work fine both on my desktop browser as well as my iPhone, so the issue must be Android related.
Ironically, most of the tutorials on youtube for a HA dashboard on a tablet are all done on Android tablets, and they all seem to work just fine, so I’m not sure why we would run into these issues.
Same issue for me.
I can see my camera from all my devices except one…
Windows laptop with Firefox : ok
Iphone with companion app : ok
Iphone with safari : ok
Old samsung android tablet with companion app : ok
Redmi Tab SE : KO (Companion & Chrome…)
Any idea ?
Thx
I see this log entry which seems related (Android tablet - older Samsung, running Android 14 now):
Source: components/system_log/__init__.py:331
First occurred: July 11, 2025 at 9:49:17 AM (9 occurrences)
Last logged: 11:40:50 AM
Uncaught error from Chrome WebView 116.0.0.0 on Android 14 TypeError: Failed to set the 'currentTime' property on 'HTMLMediaElement': The provided double value is non-finite. WebRTCCamera.connectedCallback (/webrtc/video-rtc.js:207:40) HTMLDocument.<anonymous> (/webrtc/video-rtc.js:272:26)```
I had a similar problem but I finally found the answer for me. Thought i’d post here if someone else is having my setup and problem.
My setup is a Home Assistant running on a intel nuc. Webrtc-cards work fine on pc, companion app (on Android) but not on my pad (Android running fully kiosk browser)
I was using the http://homeassistant.local:8123/ address on my Android pad. But on my pc and phone I was using the ip address http://x.x.x.x:8123/.
Changing to the ip address on my pad fixed my streaming issues.
I’m not sure exactly whats going on but I think it’s got to do with mDNS name resolution. I don’t think that the WebView implementation can resolve “.local” hostnames. So the stream fails. Again I’m not sure but it worked for me.
