Webside is empty after installation
OS Version: 13.1
Home Assistant Core: 2024.9.2
Hardware: Synology
Home Assistant is starting and seems to be ready.
Opening a webbrowser with “http://homeassistant.local:8123” redirect me to the “http://homeassistant.local:8123/onboarding.html”, but then I see only an empty white screen. What can I do?
What browser?
What ad-blocking or other security software is in use?
Browser: Chrome, Brawe, Firefox
Security: Norton 360. But also no change after deactivating.
Same here. Debian12 with docker. FF & Chrome. With 2024.8.2 everything was working well.
Correction: page is not blank but it ask me to create my home which was existing from previous version. Looks like a reset.
Daniel
Please open an issue so that this can be tracked down.
That sounds like you didn’t map /config correctly - start a fresh topic and share your compose file (or run command).
Bingo, /config wasn’t defined anymore !
Many thanks for your support
