Hello everybody,
I’m having a problem with my HA connection to AppDaemon. The websocket session cuts out almost every minute with this message:
2023-08-10 21:14:07.717520 WARNING HASS: Unexpected result from Home Assistant, id = 9
2023-08-10 21:14:07.717709 WARNING HASS: {'id': 9, 'type': 'result', 'success': False, 'error': {'code': 'unknown_error', 'message': 'Invalid JSON in response'}}
2023-08-10 21:14:07.718049 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
This therefore reloads AppDaemon every minute by no longer monitoring callbacks during this time, which is a bit annoying.
By digging a little I saw this error in the supervisor logs:
23-08-10 21:15:05 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
23-08-10 21:15:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not WSMsgType.TEXT
23-08-10 21:15:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
I searched for a while to find a solution but I can’t find anything, I even completely reinstalled AppDaemon but even with a clean configuration without an application, it doesn’t work.
Thank you in advance for your help.
