WebSocket API error: Received message 257:None is not str
several times SU is not responding, HA restarting and after the restart I found this message in the su logs.
Could you help me to debug this issue?
I don’t know which API could show this error…maybe NGINX proxy manager?
It is very annoying
22-02-18 10:52:55 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-02-18 10:52:55 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not str
22-02-18 10:52:55 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
22-02-18 10:53:40 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
Following. Have the same problem.
Do you have any solution, think i have the same problem, my HA is reboot when error is coming
22-03-08 19:40:04 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-08 19:58:40 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-03-08 19:58:57 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-08 19:58:57 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
22-03-08 19:58:57 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-08 19:59:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-08 19:59:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-08 19:59:38 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
I’m also facing the same problem any solutions
same here…any solutions?
