My log is filled with error like this after upgrade to 84.1. Any ideas?
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/connection.py", line 66, in async_handle
handler(self.hass, self, schema(msg))
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/commands.py", line 102, in handle_subscribe_events
if not connection.user.is_admin:
AttributeError: 'NoneType' object has no attribute 'is_admin'
I see it, too. It may or may not relate to 84.1’s allergy to change event subscriptions via websocket. Unfortunately, I don’t have the time at the moment to diagnose it well enough to submit a bug report.
yeah I read that … I also use the API login for my normal user. not for other applications.
I deleted the API in the http part of the config but no luck. also the images of the webpage are broken. end this is in the homeassistant.log:
2018-12-16 00:16:00 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback SendfileStreamWriter._sendfile_cb(<Future cancelled>, 26, 25, 27740, 80547, <_UnixSelecto...e debug=False>, True) Traceback (most recent call last):
File "/home/homeassistant/.pyenv/versions/3.6.3/lib/python3.6/asyncio/events.py", line 127, in _run
self._callback(*self._args)
File "/home/homeassistant/.pyenv/versions/3.6.3/envs/homeassistant-3.6.3/lib/python3.6/site-packages/aiohttp/web_fileresponse.py", line 37, in _sendfile_cb
loop.remove_writer(out_fd)
File "/home/homeassistant/.pyenv/versions/3.6.3/lib/python3.6/asyncio/selector_events.py", line 351, in remove_writer
self._ensure_fd_no_transport(fd)
File "/home/homeassistant/.pyenv/versions/3.6.3/lib/python3.6/asyncio/selector_events.py", line 258, in _ensure_fd_no_transport
fd, transport))
RuntimeError: File descriptor 26 is used by transport <_SelectorSocketTransport fd=26 read=polling write=<polling, bufsize=0>>
fd, transport))
no clue what this it or means...
