WebUntis - Timetable in HA
I just want to share my integration WebUntis.
It allows you to use data from WebUntis, for example to set your alarm clock accordingly
or just to display your timetable in HA.
Let me know if you have any ideas to improve this integration!
Discord Banner 4
is there a way to use webUntis with a MS360 User?
I wasn’t able to use the integration, using a Microsoft 360 User account.
thanks in advance,
Kurt
Sorry.
The WebUntis Python package is not compatible with an MS360 user.
ich lese hier mal mit wollte das auch schon mal instalieren aber bin neuling in sachen ha
Hi, would it be possible to put also other stuff on blacklist? Like teachers, Class or combinations?
Great integration.
Are you planning to ad information like Hausaufgaben and content of Klassenarbeiten?
Do you have a template for sending alerts if a class was cancelled?
Requesting homework is currently not supported by the Python WebUntis package, as outlined in this GitHub issue.
There is a fixed template in the code for canceled classes that is currently not modifiable.
This is a feature that I may add in the future.
In the documentation there is the sentence “Before you can use templates you need to enable the option generate JSON in the options flow. (Backend - generate JSON)”. What does that mean? How do I implement that?
When you enable this option in the option Flow the sensor will provide a json string you can use to get further informations. You can disable it to minimize server requests
Hi Jonas,
thanks for sharing your code, it sounds interesting! I am running HA in a school environment.
Is there a way to do 2FA as well? As a teacher I ll have to obey a second login factor.
Although it seems to work with my login data by viewing classes, i.e. I can see timetables of some of them in the calender sensor, I cannot get a valid login for my own schedule (see attachment, I guess this might be due to 2FA!?), students don’t have 2FA.
Infos like who is absent with a valid excuse would be a desirable information to get from this integration, etc… as well, in order to save time every day.
Glad for any reply.
RReichle
error
Hi!
Sorry for the stupid question. Where can I replace the password?
nice work. Any chance for the integration of substitute hours and cancellation of classes?
Hi, i have two girls in the same school. Is it possible to get Both of their schedules?
Right now, it does not find the students, server, school and name is correct, also tried one and two first names with no results? Any other ideas?
Wow, I want this for my son. Thank you very much. I did not understand from your setup guide - do I always have to ask school admin for access? My son has a username and a password as a pupil. Unfortunately I cannot finish the setup. The integration states “invalid password or username”. Currently the password contains a “ü”. Is that a problem for the integration?
No you only need to ask your school if you have no login credentials.
The Umlaut may cause the error. Change the password and try to setup the integration again.
I have the same situation like @atklein:
Two daughters at the same school in different classes.
In the untis mobile app I can switch between the two accounts. How do I set-up this HACS integration to pull the data for both children into homeassistant?
@atklein @Lupo
You can setup the integration for 2 students by just adding the integration 2 times with different students as source. I recommend to use the student login because it can better handle homework and exams.
Okay. That solved it. Umlaut is not allowed when using your integration. Thanks.
Sorry, I cant get a list of lessons for the next day with both of your examples on Git Documentation. I get “list object has no element 0”. I also tried it with chat GPT without Luck. Can someone please give me the correct template code?
Edit: This works
{% set raw = state_attr('sensor.jonathan_stundenplan_nachste_stunde_zum_aufstehen', 'day') %}
{% set morgen = (now() + timedelta(days=1)).date() %}
{% set eintraege = (raw | from_json if raw is string else raw) %}
{% set stunden = eintraege | selectattr('start', 'search', morgen|string) | list %}
{% if stunden | length == 0 %}
Du hast morgen keinen Unterricht.
{% else %}
  {% set faecher = namespace(liste=[]) %}
  {% for l in stunden %}
    {% set fach = (
      l.subjects[0].long_name
      if l.subjects is defined and l.subjects | length > 0 and l.subjects[0].long_name is defined and l.subjects[0].long_name != ''
      else l.lstext
      if l.lstext is defined and l.lstext != ''
      else l.name
    {% set faecher.liste = faecher.liste + [fach] %}
  {% endfor %}
  {% set anzahl = faecher.liste | length %}
  {% if anzahl == 1 %}
    Morgen hast du {{ faecher.liste[0] }}.
  {% elif anzahl == 2 %}
    Morgen hast du {{ faecher.liste[0] }} und {{ faecher.liste[1] }}.
  {% else %}
    {% set letzte = faecher.liste[-1] %}
    {% set rest = faecher.liste[:-1] | join(', ') %}
    Morgen hast du {{ rest }} und {{ letzte }}.
  {% endif %}
{% endif %}
