The current new helper is great, but only has the status On or Off.
It would be nice to add a default state for when nothing is scheduled (Off) and then when make a schedule, be able to give it a specific state.
For example I have curtains that have multi positions during the day. So the options are Open, Closed, Daytime, Evening, etc. I would be nice to be able to schedule that in one helper and not create 3 or 4 helpers for every state
An image maybe explains it better: Different color, different state.
Or a YAML Example:
# Example configuration.yaml entry
schedule:
thermostat_schedule:
name: "Thermostat schedule"
default_state: Closed
monday:
to: "09:00:00"
state: Open
to: "11:00:00"
state: Daytime
tuesday:
to: "10:00:00"
state: Open
to: "12:00:00"
state: Daytime
to: "13:00:00"
state: Evening
Agree. It would also be nice to have more granular intervals in the UI and not just 30 mins increments.
E.g. to schedule an alarm clock.
It seems only possible via yaml but not in the UI?
Agree. The state could be the required temperature for a thermostat. An automation could then be triggered by the schedule and turn the heating on and off - and also set the target temperature.
One of the features that could be helpfull is to integrate ventilation control that would allow for different fan speeds for each hour and also bypass feature ie. Party Mode to set up higer fan speed for specific time after which ventilation would follow regular program.
I could use this to schedule the preset modes (comfort, away, night, frost) of my climate entities or define different brightness levels throughout the day for my light bulbs.
A multi state option would allow easy modification from the UI without digging into an automation. That would make it a lot easier for other members of my household, who don’t have a firm grasp of how Home Assistant works, to change the schedule of an entity.
Furthermore, I think it would add clarity. As an example, I currently use a weekly schedule to control my climate entities. “On” means preset mode “comfort”, “Off” means preset mode “night”. However, you need to know this in order to make sense of it. That’s no problem for me, but it isn’t necessarily obvious for other household members. With a multi state weekly scheduler, this would be obvious since you could simply have “comfort” and “night” displayed in the schedule.
A multi-valued schedule would be extremely useful for a heating schedule. Of course, having a schedule to define the times for a set of labels and a sidebar to define some numeric value (temperature in my use case) per label would be even better than just a multi-value schedule.
Now I need 5 schedules, 5 numeric inputs and one template helper to return the temperature based on those inputs and schedules. Having at least the labels defined in a multi-value schedule would make changing those schedules a lot easier.
Hi everyone!
I was wondering if it would be possible to add a “data” field in the schedule’s entries, something like the data section of the “service call” action.
It would be very usefull, for example, to set a different temperature for thermostats during the day, instead of being just able to switch them on or off (issue already stated in this post).
I was thinking of something like the data section of the “service call” action, to be able to set multiple variables for my automations.
I think it could be an interesting addition to the schedule component!
Agreed, I am trying to setup a heating system schedule similar to my old Hive system and i want to schedule different temperatures for different times of the day. We need an option to have different states from the schedule at different times of day other than just on or off.
