Weewx interceptor issue
Hi all. I am very new to Linux and ubuntu and i have having the below issue when installing WEEwx interceptor for my Ecowitt weather station. Any help is appreciated.
Vincent Long
3:42 PM (2 minutes ago)
to me
in@vin-System-Product-Name:~$ sudo weectl extension install home/???/interceptor.zip
[sudo: authenticate] Password:
Using configuration file /etc/weewx/weewx.conf
Install extension ‘home/???/???’ (y/n)? y
File “/usr/share/weewx/weectl.py”, line 85, in
main()
File “/usr/share/weewx/weectl.py”, line 77, in main
namespace.func(namespace, extra_args)
File “/usr/share/weewx/weectllib/_init_.py”, line 82, in dispatch_with_args
_do_dispatch(namespace, extra_args)
File “/usr/share/weewx/weectllib/_init_.py”, line 111, in _do_dispatch
namespace.action_func(config_dict, namespace, extra_args)
File “/usr/share/weewx/weectllib/extension_cmd.py”, line 116, in install_extension
ext.install_extension(namespace.source, no_confirm=namespace.yes, extra_args=extra_args)
File “/usr/share/weewx/weecfg/extension.py”, line 141, in install_extension
raise InstallError(f"Path {extension_path} does not exist.")
weecfg.extension.InstallError: Path home/vin/weewx does not exist.
vin@vin-System-Product-Name:~$
Hello vin63,
Welcome to the Home Assistant Forum.
Is this question related to Home Assistant at all?
HA has a very good integration for Ecowitt that I use, if this is a Home Assistant related question, I suggest trying that.
Hi and thanks. I have no idea TBH as this was an option i found on google for my issue.
WHAT IS HOME ASSISTANT?
Start in the Home Assistant Docs here: https://www.home-assistant.io/
If you run into a specific problem, pick a topic and ask sharing what you have done and what you are trying to do.
The Home Assistant Cookbook - Index
Oh, also stay away from AI chat bots, they are not based on current data and will mess you up…
Here’s the official WeeWX support info page, with a link to their Google group for help:
https://weewx.com/support.html
Another useful WeeWX support resource is on WXForum.net:
https://www.wxforum.net/index.php?board=119.0
